HP LaserJet 3030 All-In-One Printer Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Feb 15, 2011
Anonymous
Expert
Level 2:
Answers
218
Questions
0
Helped
46784
Points
712
Steps . The first troubleshooting step an owner can take is to make sure that the plastic protective tape on the new black cartridge is off.
Next,calibrate the HP printer. One thing to remember is that every time there is a need for a new printer cartridge, calibration is one of the steps to perform right after loading. You can run "Self Test Diagnostic," as well as, "Print Cartridge Alignment" in order to get the black ink to work.
You can also try cleaning the black ink cartridge. Remove the blank ink cartridge from the HP printer; use a cotton swab to clean the laser or scanner block. Wipe away dirt, grime or any dried ink that may prevent ink from flowing. You can also try cleaning the printer heads.
  • If you are having issues on an HP Laserjet printer, go to the menu, click "Diagnostics," then print the "PQ Troubleshooting Pages." If black ink does not print, go to "Disable the Cartridge" and switch the magenta and black cartridges on the menu. Then, print the pages again. If black ink does not print, then the problem may be the toner cartridge.
    At times, when black ink does not print, it can signify a problem with a printer's laser. The owner of a HP printer may see an error on the LCD screen, indicating that there is a problem with the laser assembly.
    Another problem could be the wiring connection at the laser or scanner; check if the plugs are loose. Contact HP Support for further assistance.
  • Anonymous
    Level 3:
    Genius:
    • Master 1,570 Answers
    Anonymous
    Master
    Level 3:
    Genius:
    Answers
    1570
    Questions
    0
    Helped
    385883
    Points
    4486
    Hi
    When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
    I hope it helps you solve your problem.
    Regards
    1helpful
    My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
    Hi..
    Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
    Hope this has helped you.. Thanks..
    2helpful
    3answers
    Zebra Z4MPlus not printing dark enough
    In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
    Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
    Printer not printing dark enough
    go to the print settings select the dark scale
    u can get print darker than the previous
    3answers
    Print very light
    change your printer setting to BEST PHOTO setting
    My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
    If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
    2answers
    Toner issues
    there r two possibilities for this problem 1)either the printersettings are not set properly.try to set all the settings on darkl mode .if not getting perfect setting.just reinstall the printer drivers again,.as reinstallastion automatically sets the printer settings to the required . 2)the other thing is that the optics lens fron where the rays gets passed on the lens which reads the cartridges is got dirty and needs cleaning. to see the picture of optics lens just click the link theimage of lens /optics of a printer
    http://farm4.static.flickr.com/3104/2550956836_f1135cff1b.jpg
    Toner prints to dark
    hi!!!!!
    try to re-install the driver of your printer!!!
    or try to figureout the settings of your printer
    2helpful
    Print in light
    1. Check TONER SAVE setting. If this setting is programmed "ON", all
    printed documents will be light.
    a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
    b. Press the top or bottom navigation key (keys located above and below
    the MENU/SET key) until the display reads "Toner Save: OFF".
    c. Press MENU/SET.
    d. Press STOP/EXIT.
    2. Check the PRINT DENSITY setting. This setting allows you to adjust
    the print density from light to dark.
    a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
    b. Press the up navigation key (key above MENU/SET) to make print
    darkeror the down navigation key (key below MENU/SET) to make print
    lighter.
    c. Press MENU/SET.
    d. Press STOP/EXIT.
    Ricoh aficio 1515f printing dark line down left side
    If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
    The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
    Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
