20 Most Recent HP LaserJet 1200 Printer Questions & Answers
YOU PROBLEM IN THE FUSER STAGE MAYBE FUSER FLIM IS PROBLEM
HP LaserJet 1200... | Answered on Oct 11, 2018
HP tech support might help you in this matter you can reach them directly on this number (877-690-9305) or just follow the link Support For Hp Printer
HP LaserJet 1200... | Answered on Jan 26, 2018
Laser Scanner
HP LaserJet 1200... | Answered on Oct 10, 2017
Replace the power supply. Definately not the fuser
HP LaserJet 1200... | Answered on Oct 02, 2017
This is a memory problem, it clears when you switch it off because it clears the RAM. You need to add more memory, or better still buy a new Canon. :>)
HP LaserJet 1200... | Answered on Jun 18, 2017
Since Windows XP, the driver for the HP LasetJet 1200 is included in Windows.
HP LaserJet 1200... | Answered on Aug 12, 2015
you can't check the toner level directly.
if you conect via parallel interface make sure to install the driver for the printer. if you connect via USB the computer should recognize the printer automatically and install the driver. if it stays offline try to use the other interface or a new cable. if it doesn't help your printer may be faulty and you need to replace the formatter board
Refer to Page 66 for printing on envelope
http://h10032.www1.hp.com/ctg/Manual/bpl10395.pdf
HP LaserJet 1200... | Answered on Mar 28, 2015
Instructions for printing envelopes can be found on page 64 of the user manual. If you do not have a copy, download one from here:
Try this
http://getitherefree.net/ttfsub-gpd-download/
HP LaserJet 1200... | Answered on Nov 26, 2014
Hi
Try this solution
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
HP LaserJet 1200... | Answered on Jun 14, 2014
when all light is on printer has a fatal error ( Problem with scanner section or Fuser section)
Secondary error pls tell me is it blinking
Hello, It sounds like you need to get a maintenance kit and replace the parts in the kit, or the fuser is bad and needs too be replaced.
HP LaserJet 1200... | Answered on May 17, 2014
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
HP LaserJet 1200... | Answered on May 15, 2014
HP LaserJet 1200 Printer Logo
211 questions posted
Clive
Clive
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
printer not reset
  • Office Equipment & Supplies
