20 Most Recent Zebra Z4Mplus Label Printer Questions & Answers
Unable to reset the printer, even to reset the password
after you reset to default settings you need to save changes for it to take effect. there is also another password. 1234 will only take you to level 2 you need the level 3 password. this password can be found in the service manuals and some of the full manuals
3/1/2021 7:04:15 AM • Zebra Z4Mplus... • Answered on Mar 01, 2021
There is error "bblock"
BBlock is BOOT Block. The printer is not booting up the settings completely. Probably got corrupted. You will need to download the bootblock version for this printer & upload it via either USB or LPT1 port. You should contact Zebra so they can direct you to the proper Zebra site for the download & instructions. The process of the upload is no more that 15-20 minutes.
Zebra phone # is 847-913-2259 I think option 2 is tech support. be sure to have s# of printer & tell them you need to find the boot block & installation info for the S4M. Good luck.
3/1/2021 7:03:13 AM • Zebra Z4Mplus... • Answered on Mar 01, 2021
2answers
I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
3/1/2021 7:02:27 AM • Zebra Z4Mplus... • Answered on Mar 01, 2021
2answers
My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
3/1/2021 7:02:05 AM • Zebra Z4Mplus... • Answered on Mar 01, 2021
How do you set a static IP address on the Zebra
If this is a wireless printer then all you need to do is set an address reservation on your router and then set up a fixed IP port on your printer driver.
First: Install the printer driver as a normal USB printer by connecting the cable during the install process dont use the wizard if you can help it.
Second : Find your MAC address for the printer (all types of Network Cards MUST have one) this will either be in the LCD control panel or on the bottom of the printer on a label and set this in your admin panel of your router to say 192.168.0.10 for example. You can normally enter this using 192.168.0.1 but all routers are different. Check here for your make and model http://www.routerpasswords.com/
Last : Goto the printer driver properties for the USB printer you have just install click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install.
Thats is. !!!
9/5/2017 1:12:14 PM • Zebra Z4Mplus... • Answered on Sep 05, 2017
0answers
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
10/28/2015 10:20:52 PM • Zebra Z4Mplus... • Answered on Oct 28, 2015
Need to find out what size lables and how to program it.
Here is a link to the manufacturer's support site for your printer: Support for the Z4MPlus Industrial Printer
8/31/2015 5:29:54 AM • Zebra Z4Mplus... • Answered on Aug 31, 2015
Zebra z4mplus blanck screen
Sounds like the main board needs replacing. Google '77904m PWB" and you will get a place to buy the part. However you mentioned the IP the Z4m does not have an Ethernet option so make sure that it isn't a Z4m+.
4/3/2015 1:35:53 PM • Zebra Z4Mplus... • Answered on Apr 03, 2015
2answers
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
3/6/2015 12:50:58 PM • Zebra Z4Mplus... • Answered on Mar 06, 2015
2answers
I have a Z4M plus and it only prints half of the
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
8/19/2014 7:44:28 PM • Zebra Z4Mplus... • Answered on Aug 19, 2014
Z4m printer error condition paper out labels will just keep feeding through ?
Sounds like a miss-match on the labels you are loading and the labels it is set up for. You'll have to go into the printer properties and check (and adjust as needed) the label stock selected to make sure they match. Next check the setting on the printer its self for the same for label stock selected. Most likely you're trying to use a label stock different then it was using before.
7/16/2014 8:00:44 PM • Zebra Z4Mplus... • Answered on Jul 16, 2014
Calibration
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel. Also verify if there is no label sticked on the media gap sensor.
6/3/2014 1:19:40 PM • Zebra Z4Mplus... • Answered on Jun 03, 2014
Z4Mplus test page
Do you want to print out settings? Do you want to print a printhead check? Make sure supplies are loaded and the printer is ready to print. Turn off the printer, press X button, turn on the printer while pressing de X button and release the button after aprox 5 seconds from power on. This will print out the configuration page. Do the same but with the Pause button, and you will get a printhead quality test. Note that the test with Pause button it will stop automaticly only after some 10 printed labels . You will need to restart the printer after that, or press the cancel button several times.
6/3/2014 1:15:40 PM • Zebra Z4Mplus... • Answered on Jun 03, 2014
My zebra z4mplus printer loads all the labels on the roll and when load the labels in the printer and turn the machine on. How can I make the printer stop loading after one label comes out?
6/3/2014 1:06:02 PM • Zebra Z4Mplus... • Answered on Jun 03, 2014
Zebra Z4Mplus Label Printer Logo
285 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Zebra
  • Z Zebra
Most Popular Question
z4mplus doesnt recognize media label
  • Office Equipment & Supplies
