Child lock button stays on+ I cant switch machine on and off to clear it. Door opens and shuts ok, but machine won't start cycle chosen
Thanks
Karen Lankester
I got the same problem with the s12 72 greek version.The machine locks with the menu button down pressed for 5 seconds. But it can lock with each program seperately. So if you locked the machine with rinse for example you must select rinse and press menu down for 5 secs.If you cant remember the last program you lock it with test everything and each time keep the menu down.
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
the child lock has come onto the washing machine and I cant turn it off
