20 Most Recent LG LMV2083SW Microwave Oven Questions & Answers
5answers
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
8/3/2017 4:30:41 PM • LG LMV2083SW... • Answered on Aug 03, 2017
How does one replace the light bulb on the LG intellowave 924J
Most lamps are replaced from a door on the side of the oven
11/30/2013 3:45:31 AM • LG LMV2083SW... • Answered on Nov 30, 2013
0answers
Checked fuse and power supply still no power past the nnoise reducer
Check the connection to the Thermal control oven control
3/18/2013 3:34:48 AM • LG LMV2083SW... • Answered on Mar 18, 2013
2answers
Hi there, I'm installing an LG LMV205SW OTR
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
9/27/2011 4:34:39 AM • LG LMV2083SW... • Answered on Sep 27, 2011
2answers
Microwave shows it's on, but cannot be reset.
HI.When you try to plugged it In and the knobs are not working then possibility the control circuit connecting the knob outside does not engaged properly.The control knob that connects inside might as well been busted.Here are the steps that might be helpful. 1.Try to open both side of the oven. 2.If the motor is working and the turntable is turning then there is no problem with the motor. 3.Check the control inside and try to check and observe if the selector/knob outside does change whenever you turn the knob outside. 4.Check also the fuse inside the oven.It has an oblong shape glass covering with a lead inside. 5.If the control connection got busted which I suspect is the problem then have it fixed and soldered properly. Thank you for choosing FIXYA.
8/15/2011 2:33:25 AM • LG LMV2083SW... • Answered on Aug 15, 2011
0answers
No power. Outlet works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/18/2010 1:58:13 PM • LG LMV2083SW... • Answered on Sep 18, 2010
0answers
2answers
Can the lg lmv2083st microwave be vented to an
On page 8 of the installation manual I found, it shows that the oven can be vented to the outside. You can view it at this link:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0707162.pdf
If the link does not work, you can go to managemyhome.com and type in your model number under the "Manuals" link.
In the manual it describes three methods of venting: Room, Roof, and Wall. It also gives guidance on how to properly install the duct work.
If you have questions, please let me know. I hope this helps you.
8/21/2009 4:06:35 PM • LG LMV2083SW... • Answered on Aug 21, 2009
I need the manual to install a LG over the oven
This one is not available for free download, but a previous model's is, and it may be close enough to help you. It's here.
If that won't do, you'll have to order it.
Call L.G. at 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or
visit here.
If yours is not a US model version, I would suggest you contact the dealer from which you purchased it for the proper L.G. contact information, or refer to your owner's manual.
Or you can download the owner's manual here, but it does not have the installation instructions in it.
8/4/2009 6:01:39 PM • LG LMV2083SW... • Answered on Aug 04, 2009
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
  1. Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
  2. Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
  3. Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
  4. Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
  5. Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
3/8/2024 3:08:42 PM • LG Microwave... • Answered on Mar 08, 2024
I have an lg convection microwave oven. Can I use foil while using convection roasting?
I have a new Kitchen Aid Convection Microwave with air fryer. I've not yet used the air fryer, but today I put a pan with a roast and set to convection roast and turned it on. I put the aluminum foil over the top of the pan and it sparked. I don't know why this happened. I'd sure like someone to let me know.
1/28/2024 12:31:51 AM • LG Microwave... • Answered on Jan 28, 2024
My LG microwave says PM in the morning. How do I change it to AM. THE MANUAL DOES NOT address this. Model LMV1683ST
Push clock button and press the Up/down buttons to change time to pm.
11/5/2023 2:52:13 PM • LG Microwave... • Answered on Nov 05, 2023
LG LMV2083SW Microwave Oven Logo
23 questions posted
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
microwave locked dont know unlock
  • Microwave Ovens
