Fisher and Paykel GWL11 Top Load Washer Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Start wash cycle, within 2/3 minutes machine stops with beeps and wash,water lites blinking, hit start again, and the same problem repeats within a couple of minutes. machine is balanced, the problem happens with any sizeor type of load, drainhose seems to be clear
Richard Roth
Level 3:
Top Expert:
  • Fisher and P... Master 9,472 Answers
  • Posted on Feb 10, 2011
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629051
Points
28464
From left to right, which number lights are on. 1 on 2 off 3 off 4 on etc.... There should be 8 lights.
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 • Dishwashers
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
After first wash cycle, machine beeps and we get a
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Whirlpool DWF B00 W
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
