20 Most Recent Whirlpool GU2400XTP Built-in Dishwasher Questions & Answers
add dishwasher salt if you live in a hard-water area to prevent calcium build up, and try adding a litre of pure lemon juice to remove the initial crusting, as the calcium is highly alkaline, and the lemon juice, being acidic, neutralises it.
Whirlpool... | Answered on Feb 01, 2019
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Whirlpool... | Answered on Sep 10, 2018
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Whirlpool... | Answered on Aug 26, 2018
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Whirlpool... | Answered on May 30, 2018
you need a new cycle selector ...or "timer "....
Dilute the soap you use by 1/3 . this won't affect the soaps ability to clean, but it makes it easier on the dispenser.
Whirlpool... | Answered on Jan 23, 2018
there are several but the consenses seems to be they are not worht the money you pay but you can decide the best thing to do is a google search there are several companies Also call your local repair shops see what they offer
Whirlpool... | Answered on Jan 22, 2018
Look at the filter screen to see if anything large got past it and into the pump.
Whirlpool... | Answered on Nov 29, 2017
hi there,
i would let you try putting a small can with charcoal in it inside the dishwasher. However, you cant use it for about 1 weeks' time.
Charcoal absorbs trapped smell.
hope this helps.
Whirlpool... | Answered on Nov 18, 2017
At 14 years I would leave it alone .
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Whirlpool... | Answered on Sep 18, 2017
problem water inlet solenoid ( humming)
replace it and you get water
Whirlpool... | Answered on Sep 09, 2017
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,262 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
warranty extensions
  • Dishwashers
