I would go for getting someone else to record at studio, means they have all the professional ideas to bring to the table, solve problems, but if your just playing around in home a small focusrite 2/2 should do you, with 2 inputs for left and right mono from desk, or also dual linking in two separate channels via xlr.
Only new models will work with MAC.
Older models work only on PCs. But there mmay be 3rd party drivers for the MAC. I found one for my WK8000 by searching using Google.
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
It is possible and depends on the length of cables you will need. If you are using a fairly long run of say 50 feet, I would put a DI box with "ground lifted" to convert from unbalanced to balanced. If the cables are short, then you can probably use a unbalanced 1/4 inch plug to XLR adapter and an XLR to XLR cable between the adapter and the speakers. The system should be safe and should NOT cause any damage. Remember to run the whole interconnected system from ONE receptacle or power source.
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps:
1) Go to : http://code.google.com/p/casiousbmididriver/
2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen)
3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers
4) Restart
5) Plug in USB cable, open GarageBand, turn on Casio
6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu
7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
