20 Most Recent Casio Privia Keyboard Case Questions & Answers
I have a Casio Privia portable digital piano. As
Theres no reset that i know of. Have you checked the power box (plugs into the AC outlet) voltage and that it is working as it should?
1/7/2023 12:51:07 AM • Casio Privia... • Answered on Jan 07, 2023
I want to connect my Casio Privia PX-120 piano to
WHich driver do you download for the midi? please, I dont have any idea. can you share a link where I can install or download the driver?
1/5/2023 6:09:28 AM • Casio Privia... • Answered on Jan 05, 2023
My Casio Privia px-800 wont
12/30/2022 5:09:51 PM • Casio Privia... • Answered on Dec 30, 2022
Casio Privia PX-120 problem
https://www.casiomusicforums.com/index.php?/topic/19061-broken-keys-of-privia-px-120/https://www.youtube.com/watch?v=lREFbtqDr90https://100tutos.com/video/1664158/how-to-repair-a-stuck-key-on-a-casio-px-120-digital-keyboard/
9/30/2021 1:14:58 AM • Casio Privia... • Answered on Sep 30, 2021
How to reset the Privia Px-110 back to factory setting
Try this 1. Turn off the digital piano 2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
9/15/2021 4:40:28 PM • Casio Privia... • Answered on Sep 15, 2021
Usb driver for mac os x
Try this driver. https://code.google.com/p/casiousbmididriver/
10/26/2015 1:13:27 PM • Casio Privia... • Answered on Oct 26, 2015
One key sounds louder than the others
Hi, This is very likely to be a dirty key contact. If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact. All the best, Chris the Fader.
9/21/2014 9:43:53 PM • Casio Privia... • Answered on Sep 21, 2014
I turned my Casio px575r on, after working fine for a couple of years, and get random synth sounds and volume blasts instead of the chosen sound.
You may be running out of internal memory. Try deleting, songs & SMF etc that you may have recorded to INF AFTER moving them to an SD CARD first. IDES4 can also be used to move user tones etc and do a factory init.
8/12/2014 11:55:43 AM • Casio Privia... • Answered on Aug 12, 2014
I have a Casio PX-800
If that is one of the ones with a plastic "hinge/spring", breakage is usually fatal... keep cord and plug for junk box.
9/11/2013 5:12:31 PM • Casio Privia... • Answered on Sep 11, 2013
2answers
Hi. I'm Using PX330 as
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
7/14/2012 5:47:12 PM • Casio Privia... • Answered on Jul 14, 2012
I've recently purchased a Roland
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
6/4/2011 1:29:50 PM • Casio Privia... • Answered on Jun 04, 2011
My keyboard sounds off when
I suspect that a NOTE or other selection button is "stuck", if not physically, then electrically.
the startup of most of these devices scans the keyboard and control panel to insure all user inputs from them are at rest. When it sees one stuck, then sometimes the system hangs.
3/8/2011 5:36:02 PM • Casio Privia... • Answered on Mar 08, 2011
I purchased a second hand
Page E11 of your manual.
If you don't have the manual, download it here for the PX300:
http://www.manualnguide.com/download/manual-guide/casio-privia-px-300-digital-piano-users-manual.html
Note... other models will be similar in method for the metronome.
2/8/2011 1:05:56 AM • Casio Privia... • Answered on Feb 08, 2011
One of the black key does not make a sound
Key contacts have got contamination. They are typically conductive rubber that press rubbber pills against circuit board traces. You can clean them with 99% isoprphyl alcohol and Q tips, but it is a lot of work disassembling and great care has to be used. There are two per key which allows measurement of velocity by the delay between the two contacts.
2/5/2011 1:29:20 AM • Casio Privia... • Answered on Feb 05, 2011
Pedal jack not working. can it be repaired or
First verify that the pedal you are trying to use is the correct sense, either normally open as most or normally closed like Roland types. Jacks if physically broken can be replaced. Unit has to be opened and correct jack replaced or in some cases the jack has just broken loose from the solder on the board.
12/28/2010 2:59:17 AM • Casio Privia... • Answered on Dec 28, 2010
How could I get the complete Casio Midi driver for
TRY E-BAY.
12/22/2010 9:45:51 PM • Casio Privia... • Answered on Dec 22, 2010
You can try to dry the inside of the keyboard by taking the end of the key board off.
Take a hair dryer and place it at the end of the keyboard and let the air dry out the fluid this may take some time depends on how much fluid you have inside.
Do not use the dryer on high because the heat will warp the bed the keys fit into, this will damage the board which cost about $ 400.00 to repair. Do not turn on the key board while the fluid is still inside this can also damage the keyboard. I belive you have already turn it on because you said eight keys do not work.Do not open the keyboard because the keys will be hard to put back in the grooves the way they were.
You can try and have it repaired at American Perfect Crystal Corporation
Casio Parts Distributor 520 Eight Ave. 2nd Floor
New York, New York 10018
212-246-8292
800-345-0537
[email protected]
www.americanperfit.com
They will charge about 50-89 dollars to check it for you and if its reparable the checking fee will go toward the repair.
I wasted kool-aid in my casio privia while the keyboard was off, but made a grave mistake because I tried to repair it my self with the hair dryer at a high level. I was told that the major board was warp, that being said try not to do self repair.
12/22/2010 2:52:51 AM • Casio Privia... • Answered on Dec 22, 2010
Have a casio px 320 and trying to use it in
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
11/30/2010 4:52:53 AM • Casio Privia... • Answered on Nov 30, 2010
0answers
Casio Privia Keyboard Case Logo
47 questions posted
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
casio privia px 120 problem
  • Music
