It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Testimonial: "I upgraded the BIOS an now it works."
" 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement) " as Beep code chart" . Need to Repair the Motherboard, or Replace the Motherboard. Try USB keyboard. Best of luck
Testimonial: "Thanks, after upgrading BIOS it worked"
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
