20 Most Recent EliteGroup P4M800-M7 Motherboard Questions & Answers
harddisk maybe necessary to set single drive by 2 jumper settings. if IDE cable is used and its standing alone.
EliteGroup... | Answered on Feb 14, 2016
plug your memory out, and see what happens, you probably have faulty memory, or one of them is faulty, or faulty wiring from your ATX power supply.....i am betting its the memory, but i sense it could be electrical.....
your stuck at the boot from DVD, you must boot form C to finish installation.
EliteGroup... | Answered on Dec 14, 2014
Check if your fan is moving when you power on your computer. It probably isn't powered, try to search your motherboard map (I got one with all other manuals and safety instructions) and carefully try to connect all cables.
EliteGroup... | Answered on Jul 27, 2014
Hmmm, I have seen a few people reporting this problem with this motherboard... seems to me that it might be a bug in the bios. Well, I had exactly the same problem. It did not even give a beep sound when the memory was completely removed. I was convinced that the motherboard was faulty. Then I thought of trying the following that helped:
On the board the JCMOS1 has 3 pins and pins 1 and 2 are closed in normal operation. Moving the jumper to pins 3 and 4 puts the motherboard in clear CMOS memory mode. So this is what I tried; I move the jumper to pins 3 and 4, pressed power a few times (although I don't think that is necessary), and after about 30 seconds I moved the jumper back to pins 1 and 2. Then when I pressed power the motherboard FINALLY emitted a beep and started up. On first start up I got a message, something to the effect of "CMOS checksum error", but I was then able to go into the bios reset defaults. I then saved and went out and my motherboard has been working fine since then. Hope this helps someone who has a similar issue.
EliteGroup... | Answered on Mar 13, 2014
Voici le lien pour telechargez les pilotes de sound pour ton carte de mere.http://download.ecsusa.com/dlfileecs/driver/mb/sound/realtek/realtek.zip
EliteGroup... | Answered on Nov 23, 2013
try downloading driver pack solutions, that will do the trick, get from torrents.
EliteGroup... | Answered on Oct 09, 2013
driver audio p4m800-m7
EliteGroup... | Answered on Jul 10, 2013
Hello here are the homepages:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=9
Here are the other model ( version 3,1 )
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=9
This is important when the drivers needed to be found.
But here seems to be no drivers for windows 7.
Here is only drivers for vista and xp, and there is absolutely no guaranty, the drivers will work on windows 7.
You need to setup the bios boot settings, in order to boot from the drive.
First boot device dvd drive, and second the harddrive.
This selection is urgent, when installing windows.
Other selections maybe needed, depending on the bios version.
The sata drive, should be shown in the bios main meny, when entering the bios.
I suggest you to download the manual, if you don`t have it, and read the setup install section, for basic boot procedure.
Good luck
EliteGroup... | Answered on Feb 26, 2013
Hello here is the homepage:
Here is the other version (3.1)
Your mainboard supports P-IDE and SATA drives.
A large ide drive, is hard to find, but a sata drive does
come up to 3 tb.
But it depends what windows system you have.
Windows xp, supports up to 2 tb, with the latest service pack installed.
Good luck
EliteGroup... | Answered on Feb 16, 2013
Here is the link :
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=91
Select the one that says "On board Audio". There are two options: one for WIN Vista and the other for Win XP/2000, etc
Cheers,
Lolita
EliteGroup... | Answered on Jan 02, 2013
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
or you might download slimdrivers
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver
or
http://download.cnet.com/2000-20_4.html
just type in what you want or need be specific you might have to try a few times to get it right
also
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
EliteGroup... | Answered on May 31, 2012
Your motherboard is a BIOSTAR right ?
Ok there are 2 versions I will post the drivers for those 2 versions.
P4M800-M7A v1.0
http://www.biostar-usa.com/app/en%2Dus/mb/driver.php?S_ID=92
These are the complete drivers, the sound driver is there too under onboard audio.
P4M800-M7A v7.0
http://www.biostar-usa.com/app/en%2Dus/mb/driver.php?S_ID=93
From what I can see they both use the same drivers.
I hope this helps.
The elitegroup website has a similar name but no A at the end
P4M800-M7
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=531&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
So from your model I would say it is a biostar, get it from the links above, if it is an elitegroup (ECS) get it from the last link.
Hi endryyakuza,
The VGA card your referring to is VIA/S3G P4M800 VGA Driver . And you can find that driver HERE.
Good Luck,
Mark
EliteGroup... | Answered on May 12, 2012
Microsoft has a program that will run on your current PC. It will check & confirm if your system can handel Vista. It will also show you what is not compatible with Vista. It will check every piece of hardware including your board & even your printer if it's connected & turned on.
It's a must use program for people who are thinking of installing Vista.
Click the link provided: http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Than click Download Windows Vista Upgrade Advisor
Good luck...
& please vote.... Thanks
EliteGroup... | Answered on Mar 30, 2012
Out the windows installation disk in the drive and restart the computer. When the screen pops up select to install windows and Format the hard drive. That is the easiest way to do it.
EliteGroup... | Answered on Nov 23, 2011
EliteGroup P4M800-M7 Motherboard Logo
159 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
want vga driver
  • Computers & Internet
