20 Most Recent Dell Dimension 2400 PC Desktop Questions & Answers
How do i widen my screen
three little dots - ... - right at top of the page you are working on, click into them.
10/7/2023 10:36:54 PM • Dell Dimension... • Answered on Oct 07, 2023
6answers
Hard drive failure in system less than 2 years old!!
Since you are comfortable with working inside your computer, the best thing to do now is to purchase an external enclosure for your type of hard drive, SATA or EIDE.
Alternately you can use a live linux cd, boot up with that, and transfer your data to an external drive.
Once your data is safe, try booting to the Windows cd and attempt a repair installation.
And finally, yes, hard drives can go bad in 2 years or less.
11/8/2022 11:34:11 AM • Dell Dimension... • Answered on Nov 08, 2022
3answers
I request to install a DVD decoder on my computer
Hi...
U can download the DVD decoder in the belwo link
http://en.kioskea.net/download/download-972-dvd-decoder-pack
and to install refer this link
http://www.ehow.com/how_5118635_install-dvd-decoder-windows-xp.html
Good Luck:-)
4/30/2022 11:35:22 AM • Dell Dimension... • Answered on Apr 30, 2022
2answers
Can't launch itunes after installing it keep
Completely uninstall the software, reboot the computer then reinstall. I recommend that you download the newest version from itunes.com
1/16/2021 10:32:50 PM • Dell Dimension... • Answered on Jan 16, 2021
3answers
Can't get tower cover off
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
  1. Lay your computer on its side with the computer cover facing up.
  2. If your computer cover has a cover latch, slide and hold the cover latch.
  3. Grip the indents on the computer cover, and slide the computer cover toward the back of the computer.
dell open cover-undefined-undefined-0.jpg Place the computer cover on a level surface.
6/2/2020 10:45:39 AM • Dell Dimension... • Answered on Jun 02, 2020
2answers
I cant play the video that i download , said i need a h264 codec
codec are basicaly needed to watch andy videos or music files....
get FFDSHOW codec from google, it's the best
11/13/2019 3:11:13 AM • Dell Dimension... • Answered on Nov 13, 2019
4answers
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
5/3/2019 3:08:45 PM • Dell Dimension... • Answered on May 03, 2019
UPDATE FOR DRIVER VER.6.14.10.4544? DELL 2400 WHEN I PLAY VLC, OR ANY OTHER VIDEO THE SCREEN SHOWS MANY FLASHING RECTANGLES
the mail problem with those dells is the video card was not very good. you can go to dell and put in the tag number and download the drivers for it and that might help. the old dell was a xp machine and it might be the only drivers you can get for that. if you have upgraded to windows 7 there are not drivers for that in w7
9/17/2018 12:42:42 AM • Dell Dimension... • Answered on Sep 17, 2018
3answers
Desktop icon are missing & display is not
Try to uninstall and reinstall the display drivers. For the desktop icons, right click desktop->Arrange icons by->show desktop icons.
8/6/2018 2:08:38 PM • Dell Dimension... • Answered on Aug 06, 2018
Dell dimension 2400 series...used to
test the PSU yet, the jumper clip tests? are the fans dead? http://www.pcdied.com/power.html bad PSU PSU overloaded or worse. ask
7/2/2018 8:32:18 PM • Dell Dimension... • Answered on Jul 02, 2018
4answers
Need an on-line owners manual for Dell dimension dim 2400
You can download the owners manual in PDF form at the following Link:http://support.dell.com/support/edocs/systems/dim2400/en/index.htm
7/2/2018 8:20:34 PM • Dell Dimension... • Answered on Jul 02, 2018
2answers
How do i unblock woozworld.com
check your parental settings - log in as administrator and turn off parental settings. this should solve the problem on a windows 7 machine.
7/2/2018 8:17:13 PM • Dell Dimension... • Answered on Jul 02, 2018
2answers
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
6/30/2018 12:11:47 PM • Dell Dimension... • Answered on Jun 30, 2018
2answers
How do i get connected to internet
you got drivers on dvd. find the dvd, and usually it's the one with dell logo. you have to install Drivers from that and your dell will Fly. You have to install: graphic card dvd, dell dvd, and audio drivers. also, check in control panel/system/hardware  if in front of system components there's a ? mark or !. install those things.
1/30/2018 11:52:53 AM • Dell Dimension... • Answered on Jan 30, 2018
How to download games from net directly
Hi, just use the steam service online they are very reliable, www.store.steampowered.com
1/9/2018 6:40:50 AM • Dell Dimension... • Answered on Jan 09, 2018
2answers
I installed Windows XP and now my Movie Maker
Here's the Microsoft Page for using Movie Maker on XP,
http://www.microsoft.com/windowsxp/using/moviemaker/default.mspx
and here's the Download Site for Movie Maker XP,
http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
It's installed through Windows Update normally so you should just install every Windows XP Update available. Go to the Start Button>All Programs> Windows Update and click on it. Follow all the prompts and say yes or ok to everything.
Good Luck
12/30/2017 3:59:14 AM • Dell Dimension... • Answered on Dec 30, 2017
19answers
How to fix a dell monitor dimension 2400 power button broken
The last guest left us hanging with, "easy fix" so, I ventured ahead to see what I could see by opening up my lcd, which was a puzzle in itself. After UNPLUGGING the monitor and removing the stand and the 4 obvious screws in the back, turn the monitor onto its back and placing your palms against one side of the monitor, and using your FINGER TIPS, gently pull back the plastic lip away from the LCD screen. Move along the lip, doing this a little bit at a time. You'll hear and feel it snap loose. Repeat on the remaining three sides. It may take a few rotations to free all the sides, doing a little at a time, so as not to put undo stress on the plastic that is not yet loose. The bottom lip from behind which lies the offending "on/off" button will not move as freely as the other sides because of the ribbon cord that attaches the circuit panel to the main body. So STOP pulling when you feel it become taught and carefully turn the monitor onto its face to complete the face's removal. Undo the cloth tape that secures the ribbon cable to the monitor. This will give you the necessary slack you need to do your dirty work. BTW, we're not disconnecting the ribbon cable from its connections- that would be bad - just remove that haphazardly placed piece of tape used to keep the thing snug and save it for when you're ready to close it back up. OKAY! There a four tiny screws that affix the green circuit board. You'll need a thin, jewelers type phillips head or a one from a synthe-sized tool set to remove these. Now, if your issue is like mine, you'll see when you again carefully remove the circuit board, that the on/off button has cracked off of the piece that holds it. This is why the button remained stuck in one positon when it was depressed. Re-align it so that it is uniform to the other buttons and place a few small strips of cut electrical tape to hold it in place to the end where it broke off. Crazy glue or the like won't give the button the flexability it needs and will probably just crack again. What the tape (I layered 3 strips) will do, once the circuit board is scewed back, is allow the button to return to position after it's pushed. I just did this and so far, after a dozen on/offs it's still working. Good luck. Go have a beer.
9/11/2017 11:57:48 AM • Dell Dimension... • Answered on Sep 11, 2017
I called epson because for some reason suddenly (i
You need to reset it to factory defaults. Several youtube videos can help you (I have exact printer but book is put away). Have you done anything to it lately with ink cartridges and the like? may need to get some mineral spirits, take out ink cartridges, and clean contacts with swab. Try the reset first, though.
8/3/2017 11:11:41 AM • Dell Dimension... • Answered on Aug 03, 2017
4answers
Dell dimension 2400 hit by lightning. the green
it can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
12/27/2016 7:02:53 AM • Dell Dimension... • Answered on Dec 27, 2016
My dell computer suddenly won't connect to the
if you right click on my computer and go to manage you should be given a window with the device manager listed. click on device manager and all your devices will be listed there. if any have a question mark than more than likely your driver is not installed or installed incorrectly. if there are any red exclamation marks or red x's than your device is not working or disabled. you can always right click on the device and go to properties to read further about it. if it is disabled you can try to enable it here but you may have to enable it in the bios durring the boot up process of the computer. if none of this is the case or does not work than your ethernet port probably got surged and no longer work a sure way to tell if this is the case is to look at the port the lights should only come on if the cable is plugged in and the computer is turned on. if the lights do not come on or stay on even when it is unplugged than your port is bad and you can just run to walmart and get a pci network card for like $15.
12/21/2016 4:16:23 AM • Dell Dimension... • Answered on Dec 21, 2016
Dell Dimension 2400 PC Desktop Logo
2,193 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
need line owners manual dell dimension
  • Computers & Internet
