E-Machines eMachines Desktop PC Logo
Timothy Bouthiette Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for the front panel wiring diagram for a emachine T4510. The Power LED & the Power SW are disconnected! HDD LED was never unplugged! I need to know where they need to be!
Curtis Richner
Level 3:
Master:
  • Master 461 Answers
  • Posted on Jan 30, 2011
Curtis Richner
Master
Level 3:
Master:
Answers
461
Questions
0
Helped
195601
Points
1190
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
I have an emachine W3080 that I unplugged the front panel wiring, power switch, power LED, and floppy LED and dont remember which pins they plug into. Can you help?
their should be some abrevations like pwr led, pwr sw, hdd led by some metal pins in one of the corner of the motherboard
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
5helpful
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
3helpful
2answers
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
1helpful
2answers
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
4helpful
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
2helpful
Emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
