eMachines W3623 PC Desktop Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My emachine W3623 starts with three beeps, and runs but nothing comes on the monitor
Igor Mateski
Level 2:
  • Expert 277 Answers
  • Posted on Jan 19, 2011
Igor Mateski
Expert
Level 2:
Answers
277
Questions
0
Helped
90412
Points
839
Remove the RAM and start the PC again. If you get the same three beeps then you're probably looking at bad RAM. If however, the PC makes no noise, or other beep code, then it's not the RAM and in that case it may be the graphics card. In this case, you'll need to do a reflow/resolder of the graphics chip with a hot air gun.
If this was helpful and informative, please give it a Thumb Up. Thank you.
aravind shet
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 141 Answers
aravind shet
Expert
Level 2:
Filmmaker:
Answers
141
Questions
0
Helped
45200
Points
479
Open CPU, remove RAM and put it back, If you have Grapic card then remove that and put it back, then reset the BIOS by removing the CMOS battery for 1 minite or more and put it back. and connect all cables, etc etc and power on the PC. best of LUck
Fresh install of XP on eMachines W3623 ..No sound
Try This:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1458
Once you are on this site choose the Operating System (XP,Vista,Win7) and losnd the sound drivers. If you do not see any sound or audio drivers download and install the Chip set drivers.
Good Luck!!
Windows fails to start on my e-machine w3623 with windows vista
where does the comnputer fail to load at. If you have installed windows again and the computer fails to start it is a hard drive or cable problem. Does the computer give you a error message (like 1XX,2XX,3XX Etc.
2answers
Emachine w3623.when i put the computer on there is 3 beeps
you should try checking your ram if it is faulty, try to clean the lids of the memory using an eraser and connect it again.
1helpful
Computer start but wont Boot up.
Here are a couple steps you can do to verify something didn't come on correctly.
- Verify the monitor cable is connected tightly to the monitor and PC.
- Verify the power cable is plugged in.
If both of these check out is there a little LED light on your monitor that is on?
If not swap it out with another monitor and see if a different one works. If so we have a bad monitor.
If both do not work you may have a video card issue. Most EMachines come with a onboard video card which is bad news. If you have a onboard video card you will have to verify the warrantly though Emachine and get it fixed. Good luck and I hope things go well.
Emachine W3623...(problems)
I had same problem,and what I did was to clean all around the fan and the aluminum air cooler ontop of the prccessor.After that it worked smooth till it got dirty again.Have you tried this.letm
1helpful
Emachine w2686 no display when boot up
Couple things to check. First, check with different monitor. Their monitors are usually build by KDS and I think there was a bad series out there. Also check for any beep codes through speakers on startup, this can tell you bad ram or bad video out. Also try unplugging computer and removing CMOS battery inside (watch like battery). Lastly, If non of the above, a bad processor will allow the computer to come on but no beep, no boot, no nothing but fans and green power light. Hope this helps a little.....
3answers
EMachine W3623 Vista not accepting router
well the router is not going to work because of the fact that the router is not compatible with vista
vista sucks
Start up
Try to boot in safe mode, if you still get nothing try a dirrent monitor, just to rule out the monitor then we can work on the computer.
7answers
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
