20 Most Recent
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Questions & Answers
Wont boot
If it is checking the key board and hard disk lights are ON ,then try fixing the memory card(s) frist after taking out one by one. If it still dont work check your hard disk by testing it on some other PC.If it dont work ther also than Disk is crashed.
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
Have a T5026. There was a problem with the power
Make sure that you have the monitor plugged into your video card if you have one (usually a horizontal port), and not your motherboard(usually a vertical port).
If it's not a plug issue, then if you press F8 repeatedly while the computer is starting, Windows will give you a boot menu, select the option "Enable VGA Mode" and windows will revert the resolution to a more common one, and will allow you to reset the resolution to one that your video processor can handle.
How do i take the top cover off a emachines t5026?
Hello cw robin, hi, you need to remove the power supply out of the casing. loosen the side cover screw at the back left side. side of, reveals the power supply box, Now remove the 4 screw on the Fan exhaust side. There is a release lever on the bottom of the power supply like a ball shape lock, press it and it releases the power supply box.
remove the connections on the motherboards and drives.
Power supply out, there are small screw on the power supply box, remove it. open and you have now access to the power supply board.
I have a T5026 EMachine won't power up. Green
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
I have an emachine T5026
The answer is no, one slot doesn't support more than 1GB ram. You cannot install more than 1GB of Ram per slot. If you are upgrading your ram to 4GB, you have to buy four 1GB rams. If you haven't purchased, go for 1GB not 2GB.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
When I turn on my machine, I get 3 beeps and my
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
FAN RUNS BUT NO OUTPUT
It has failed, although if you open it up carefully, there is a...or there maybe a fuse like a 13amp but of a much lower capacity which sometimes after some usage blows. This usualyl renders the unit dead as a dodo. Frankly its always best to buy new .... dirt cheap on ebay!
If I need to send some papers to some other place
You will need a scanner or a printer with a scan function. When you scan you can choose what format you want to save it as.
Gif and jpg are images that can be opened with any graphics program. Pdf files require Adobe Reader to open them.
Hope this helps.
Thanks for using Fixya.
Power Supply Problem
Hi, I came acroos a similar problem on an older model of emachine. If I remember it right what I did was to update the chipset and agp and other drivers (especially the lan card). The T5026 uses Intel 915GV. Most of what you probably would need can be found at http://downloadfinder.intel.com/scripts-df-external/Support_Intel.aspx?lang=eng. Most of the updates are chipset and OS specific. Good luck and please let me know how this works out for your. Cheers.
Hi. I returned from vacation and turned on my
Your Power supply is most likely dead.
A power strip is not sufficient protection against black outs, brown outs, power surges and other electrical interruptions that occur in the house. Many PC components are very sensitive to fluctuations in power and power supplies often are among the first casualties when a serious problem occurs.
To protect yourself against these common power issues you should invest in an Uninterruptible Power Supply or UPS. A UPS is basically a battery backup that will provide power when brown-outs or black-outs occur and will protect the delicate electronics in your PC. You can purchase them at most stores that sell computers and components.
