20 Most Recent
eMachines W5243 Refurbished AMD Desktop Computer - AMD Athlon 64 3800+ 2.4GHz , 1GB DDR2, 250GB Questions & Answers
My Emachine W5243 is getting
Your computer is running for sh-- because you probably have too many items starting up at boot time and running in the back ground. You have to go into your msconfig files and services,.msc files to turn off unnecessary operations. And virus programs are notorious for using up memory resources and turning computer into a snail. If you have one, get rid of it and stay off the p-rn sites.
It is not the cpu or power supply responsible for the issue. It is the user at fault for overloading the machine's resources. And a new computer will get just as bad if you continue to employ the same habits as you have with this unit.
I bought the computer on january in walmart and
Wallmart should have put you in touch with eMachine's support site so you can take advantage of the warranty, here is the web address >>>>>>>>
http://www.emachines.com/support/
Make sure you have all the documents that you got with the computer when you contact them including your receipt.
Good luck.
How to download to my computer from a dvd
Movie DVD's are not legal to pull information off, that is why they are copyrighted. If this is an information disk and you are not just able to drag and drop the information contact the publisher.
Installation guide for video card on a emachines
Providing this card is compatible with your system you just open the side, take out the screw or clip remove the old card and install the new one, upon boot up insert the CD that came with the card. Or let Found new hardware wizard take over.Also it's handy to have another computer nearby to serial connect to so that you may view that screen.
No dial tone being recognized.
try downloading updated drivers for your modem and...please make sure the phone cord is plugged into the line side and not the side with the pic of a phone on the modem.
W3502 emachine SM Bus Controller driver
Looks promising. It's an INF fie which are driver files. Download, extract, and direct Device Manager where to install driver from. The worst that can happen is it won't install, or you have uninstall / delete. Better than those fake drivers you mentioned.
