SOURCE: hotpoint aquarius stopped working full of washing
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
SOURCE: while on a cotton wash machine continues until the
You need to clean the filter.
Remove lower rear panel of washer/
Locate and remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Rempve hose onto pump, and check for blockage and or obstruction here as well.
This should solve the problem.
Please leave feed back for my solution.
Thankyou.
