SOURCE: my pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
SOURCE: I have an older pool, and it has a purex triton
You can not backwash a catridge filter. If cleaning them doesn't work they need to be replaced. A common 'issue' with cartridge filters - replacing the expensive elements every few years. There is no other way to clean them that will not in turn destroy the filter material in the process so new ones are your only choice.
John
Testimonial: "Thank you so much!! That really helps me out a lot and now I can deal with the replacement issues! "
SOURCE: have a pentair ccp320 filter.brand
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
