Please see the HP solution center for your laptop here.
Also consult the solve a problem area, specifically this section, and try to work through the solutions offered there.
Otherwise, please write back with the exact error message your are getting and what steps you have take to solve the problem, and we'll be happy to help you sort it out...
.I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
If it's an error in the tcp/ip stack open a CMD box.
At the command prompt, copy and paste (or type) the following command and then press ENTER:
netsh int ip reset c:\resetlog.txt
Note If you do not want to specify a directory path for the log file, use the following command:
netsh int ip reset resetlog.txt
reboot computer
don't forget if you are running vista or 7 you must open the CMD as admin
Is this a "Stack overflow problem" and do you get a code after the message?
