20 Most Recent HP Compaq nc2400 Notebook Questions & Answers
nc2400. (circa , 2007 made) and still supported at HP (we arent HP)
another old., pc dead. value is $20 (see ebay solds? yes)
so it less dead like this.
here are the steps,
main battery out, ? work now,
that is correct, BIOS works , with no battery, AC PACK good, 19vdc = good.
and hdd out , cd out.
ever heard OF CCFL ?
2010 then ended, so I first check this , yours being 2007
BINGO CCFLs, they are short lived lamps back lamps.
so use a flash light.
btw the externa VGA jack needs Fn+F4 pressed to work!!!
per manual below.
your SM is here
http://h10032.www1.hp.com/ctg/Manual/c02012281
now the test, acid test on CCFL.
with bios hot keys hammered, per book above.
then the magic flash light trick, (posted here now 300 times)
look ma, no blacklight.. but gee see the data., BINGO.
http://www.pcdied.com/monitors.html#flashlighttest
HP Compaq nc2400... | Answered on Sep 28, 2017
you have to remove the HDD cover and check it may be out of socket
HP Compaq nc2400... | Answered on Aug 19, 2013
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
HP Compaq nc2400... | Answered on Feb 27, 2013
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
HP Compaq nc2400... | Answered on Nov 30, 2012
Please see the HP solution center for your laptop here.
Also consult the solve a problem area, specifically this section, and try to work through the solutions offered there.
Otherwise, please write back with the exact error message your are getting and what steps you have take to solve the problem, and we'll be happy to help you sort it out...
.I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
HP Compaq nc2400... | Answered on Jan 05, 2011
try hooking it up to a external monitor to see if the internal monitor is working property.
HP Computers &... | Answered Yesterday
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
HP Computers &... | Answered 2 days ago
...****WARNING THIS POST IS SPAM**** NEVER CALL ANY NUMBER POSTED IN ANY POST ON THIS WEBSITE. YOUR CREDIT INFORMATION AND COMPUTER ARE IN DANGER HERE...DONT BE STOOPID...AND TO THE IDJITS POSTING THIS JUNK. GO FIND REAL JOBS....30
Vishal, Your message does not qualify as a question or query for a problem, try somewhere else
HP Computers &... | Answered on Oct 11, 2019
Brodrew Smith, Your message does not qualify as a question or query for a problem, try somewhere else
HP Computers &... | Answered on Oct 10, 2019
HP Compaq nc2400 Notebook Logo
Popular Tags
13 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
compaq nc2400 no video
  • Computers & Internet
