20 Most Recent HP Compaq Motherboard Questions & Answers
let me read all 3 posts, why not just have one and comment to one?
symptoms for all, do nor read posts from folks telling you to find fuse clips seen in 1980s, PC, forget that. this is all SMD parts.
wiki that....
  • previous owner used a AC/power pack and blew up this LT..
  • its 19vdc not 24vac, or you WILL BLOW IT UP.
  • fixing that if true is non trivial to say the least.
  • it will not power on with battery removed, and with correct 19vdc pack attached,
  • or it does turn on sometimes but locks up in XP screens.
  • This is a 13 year old LT. so fixing one this old is dicey.
  • (reason is XP is dead OS and parts hard to find)
  • why look for fuses. if a fuse works on 1 boot why would it fail 2nd boot? answer its not a fuse its dream of a fuse. (hope)
  • Does BIOS screens work,
  • Does using a DT screen on the rear 15p, VGA port work can the external screen be made to work.
  • Does booting to any bootable CD work, HP windows install or live LINUX cd, or window live PE CD work. if yes the LT is ok
  • just has bad OS or BAD HDD.
  • Power dead totally and 19vdc on the MOBO input pins
  • is a dead mobo, no BIOS,on both screens, 19vdc in is a dead mobo. The fuse if present are SMD fuses F1,F1, if mobo marked, L1, L2, those are inductors not fuse... nice try though.
http://jeepdied.com/look/puters/dead-screen.html
HP Compaq... | Answered on Apr 04, 2017
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
HP Compaq... | Answered on Feb 27, 2017
Rich, there is no info on that number. I need the name & model# of the computer it came out of. If it is a Compaq, then it is old and may be difficult to find, but we can't go anywhere without that info.
HP Compaq... | Answered on Dec 05, 2016
Every driver for your motherboard can be downloaded from: Driver Update Software for XP Vista 7 8. Wish you best of luck. Cheers
HP Compaq... | Answered on Jun 19, 2015
If you post what model I would suggest what link with let you download the appropriate drivers and if that doesn't work next step will be disassemble the computer and replace the speakers itself and the last solution would be change the motherboard as it will bring bring new working audio port on it.
HP Compaq... | Answered on Jul 05, 2014
it is a power plug that goes hear the cpu socket area
HP Compaq... | Answered on May 25, 2014
nesecito una targeta de video que tipo de tarjeta debe de ser
HP Compaq... | Answered on May 20, 2014
Cklick on this picture and you will know...You have to connect all three to "Front Panel" connector the way it shows on this picture...
http://img33.imageshack.us/img33/9223/11frontpanelinstall37sc.jpg
HP Compaq... | Answered on May 18, 2014
Care este modelul Compaq?
HP Compaq... | Answered on May 13, 2014
check to see if it is plug in board the right way
HP Compaq... | Answered on Mar 22, 2014
download /driver identifier
HP Compaq... | Answered on Feb 17, 2014
HP Compaq Motherboard Logo
349 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
ms 7525 ver 1 0 motherboard drivers
  • Computers & Internet
