My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
Good Morning Friend,
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
Mine is on concrete floor. And when it spins, it wobbles so much that it manages to unplug itself. Does anyone have any solutions about that?
when it goes to the sspin cycle it bounces all over the place and will eventually unplug itself. Some oone said a pedistol would help is this true? I am about ready to back to a traditional machine
2 identical units, both on trussed floors.
Balanced and level - checked several times runs wobbly even when empty
My front loader I've had since June and have only been able to use it maybe 5 times due to it shaking so bad. We removed the shipping bolts and re-enforced the floor and still nothing. We also have the pedestals and still shakes like crazy. I don't know what else to do. I really am very disappointed with this and regret spending as much as I did and have to do laundry at my in-laws
Is it on concrete or a "main floor" with floor trusses?
how old is it
