Hotpoint WMA58 Front Load Washer Logo
Posted on Dec 17, 2010
The door does not lock. Can you buy a new lock
The door does not lock. Can you buy a new lock without buying a new door
Hugh Burgess
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jan 01, 2011
 Hugh Burgess
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
4322
Points
46
Hi
Yes you can buy either a new door catch or the interlock switch for under £10.
Try espares or barty spares on ebay.
Be careful if the door lock light is flashing as this could be the same problem as mine having replaced both items and the pcb control panel. It might be motor brushes causing a short in the pcb board awaiting answer from expert pcb is £100 brushes £15
HB
How do I open rear passenger side door on 2010 santa fe lock actuator stuck in lock position. Can't remove door panel without breaking cant access screws with door closed
Call the dealer ask a mechanic how to open door they likely have a trick and they want you to buy the parts so ask for an exploded view of door and lock you might be able to fish the window and yank the lock bar
Lost door key,can new key be made without copy
you can buy brand new oem for about $20.00 online also can check ebay and other locations the old keys use to have a little tab in them and they would pop them out and give to owner dealers can do a vin cut on key but it is cheaper to replace the whole lock with new keys for the older cars
http://www.best-deal.com/search/landing/query/corvette+door+locks/s/yahoo/?utm_source=bing&utm_medium=cpc&utm_campaign=Cars_1&utm_term=corvette%20door%20locks
What is the process to replace passenger door on 1999 f150
remove the door panel. remove all wiring and exit the wiring harness out of the door completely. next remove the bolts that attach the hinge to the door. remove the lock assy so that you can retrieve the key cylinder. if you buy a new door you'll need all the guts to the door. if you buy salvage yard all you may need is the lock cylinder
Are the door locks on a fuse system,what do I need to buy
Door locks are fused and most are run from a relay. Don't buy anything until the lock system is properly diagnosed so you do not end up buying parts that are not needed and can't be returned
My Wf000 door Locked is flashing, machine will not lock?
You can try this.
Switch off the washing machine at the mains, unplug it and leave it unplugged for about 5 minutes.
Plug it back in and see if it will work.
If it doesn't work you may need to buy a new door lock mechanism. The door lock has some electronics which can fail sometimes. You can buy the door lock on the internet for about twenty pounds and can do it yourself if you are fairly handy. There are also videos explaining how to do it on YouTube.
It worked for me.
Good luck
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
What tool and size of tool do i need to remove a 1998 volkswagon beetle door lock?
You need a special tool that has a hook at the end and is bent in the middle (T 10034). This will easily position a lock spring into door lock mechanism. I'd suggest you buy a set of 1/4" Torx bits so you can work with VW fasteners. They are affordable and available at any auto parts or go to Sears. You attach this bits to a 1/4" socket and a 1/4" ratchet for tight fitting bolts.
Remember, it will be difficult installing a new lock mechanism without the spring tool.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
