2004 Chevrolet Express Logo
Posted on Jul 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hey ya i figured that is where it was but the housing goes sideways it is going to be a hard job... if that is my problem i am having issues in town it is running hotter than it should be and overheating when pulling a trailer while i am in third gear do you think i should flush the antifreeze first
Pierre Laplante
Level 3:
  • Chevrolet Master 2,061 Answers
  • Posted on Jul 11, 2008
Pierre Laplante
Chevrolet Master
Level 3:
Answers
2061
Questions
Helped
789448
Points
21147
Radiator not the greatest when you ask the engine for more power radiator doesnt cool engine enought thanks pierre
Pulls to left while hard acceleration pulls to the right after shift and rpm's drop off
Probly done wrong. Get it realined or havit inspected at a specialist not a dealer. Also send issue to [email protected]
3answers
How do i fix the blower stuck on high
if it only goes on high, the resistor needs to be changed . It is on firewall ,passenger side of car under wiper assembly behind alternator. not a hard job to do, part is not expensive. you will get low,med , and high back. if not switch on dash panel, or change blower motor, last ,since it is going on- working. good luck
How do I pull the engine out of my suzuki reno
first thing i would do would be to go down to your local parts house and get a chilton or haynes manual and they will give you a step by step walk threw of pulling your motor. when its all said and done you'll see that it aint that hard of a job. that is if ya have a clean place to do the work.
1helpful
Cranksensor where is it location at 2005 town and country
Hello melvin453: My name is Roger and I will help you. The crank position sensor is located on the rear of the transmission housing above the differential housing. The bottom of the sensor is located next to the drive plate (flywheel). Should you need further help please just ask.Please rate the answer. This way i know it was helpful. Thank You for using Fix Ya.
I am trying to figure out if I can get a TPS or
Take your IAC off first and clean the pintle (pointed end) with carb cleaner or throttle body cleaner spray , plus spray into the hole it comes out of and clean well in there too. Now re-assemble, and try it. Sometimes cleaning will do for now.
My lincoln town car wont start. I turn the key and all power goes out.
Hey Ircarlton..my name is Keith..and i had this to happen to my Ford...and it was the battery..i hope this helps ya solve ya problem
1helpful
2008 Town & Country Brake Job Advice
no special tools required for pads and rotor replacement.
Did you figure out the double posting problem?
how ya doing .... nope not sure if they have fixed their website yet. .. i hate ff too.... oh put on new rotors and pads on my van today.... should have seen the rotors lol
Robert
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
