I also have the same problem wit my affinity but no solutions have been found. Any one knows?I also have the same problem wit my affinity but no solutions have been found. Any one knows?
AnonymousJun 06, 2017
My Affinity doing the same. Changing lock assembly does not resolve the problem.My Affinity doing the same. Changing lock assembly does not resolve the problem.
You can't post conmments that contain an email address.
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
I'm having the same problem, but my affinity is about a year old.
