Bunn Pour-O-Matic  VPR Logo
Posted on Dec 01, 2010
Cleaned my pot but the water is running very slow. when I emty the pot the water flows very good out of the hole but when I make the coffee is does not flow very well taking about 15 min to make a pot of coffee thanks for your help
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Dec 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
3740
Points
33
First thing to check is that there is no blockage in the funnel. Next thing is check the spray head and make sure that it is not limed up. After removing the funnel there will be a round silver head that screws in above the funnel, it can be removed by hand but usually you need a pair of channel locks. If so you can clean the spray head with a wire brush. Also if that is not an issue you can purchase a deliming spring from http://www.google.com/imgres?imgurl=http://ecx.images-amazon.com/images/I/21IeXJoqjnL._SL500_AA300_.jpg&imgrefurl=http://www.amazon.com/Bunn-Commercial-Deliming-Spring/dp/B0032QNRH2&usg=__mJkJExy1qExfrZEEbtxW6EAQGSw=&h=300&w=300&sz=5&hl=en&start=4&zoom=1&itbs=1&tbnid=tHf1BPtEJIafsM:&tbnh=116&tbnw=116&prev=/images%3Fq%3Ddeliming%2Bspring%26hl%3Den%26gbv%3D2%26tbs%3Disch:1
WIth the deliming spring you need to remove the spray head and simply run the spring through the hole til you hit the water in the tank and pull it back and forth about 4 or 5 times. Also something siple make sure there is only one coffee filter it is easy to put two in. Hope this helps.
www.midstatebeverage.com
I have an older model cuisinart 12 cup coffee maker. This am the water will only slow drip through the filter. There is lots of gurgling but not much coffee. Can u help me figure out what's wrong?
Calcium buildup. Follow your coffee maker's manual cleaning procedures to dissolve the hardness buildup.
If you can't find your manual, try mixing 1-2 cup of white vinegar in an 8-oz to 12-oz pot of water and pour it into the water receptor. Run the coffee maker until about 1/2 the water has passed through the machine then turn it off and let it stand for awhile (say an hour). Then turn it back on and let it finish. This should dissolve the hardness buildup in the machine and restore the flow. If not repeat. If you use a paper filter during the process, you should capture all sorts of hardness particles.
After it's flowing good again, run with one or two pots of water to rinse.
2answers
Slow water dispensing
How slowly in comparison to other units? Have you measured it how fast it runs ?? If slower than when Syntia was brand new is maybe caused by an insufficiently cleaned brew group or lack of proper descaling .Calcium or mineral in the unit's lines and boiler can slow down your machine .
if the filter screen is partially blocked from old coffee tar then water cannot flow faster . In my opinion it always runs slowly when rinsing .
If you use a "Coffee Residue cleaner "only use it in the pre-ground
setting chute and use only a pinch at a time . then run pre-ground setting without any grounds and run another one to clear the detergent
Very oily ,sticky coffee beans can plug up any late model superautomatic's system as you can read in the unit manuals . Because the laser cut holes in the fliter screen are so small that any coffee tar will not flow properly through the screens .I have had many machines which had to be switched to a less oily bean to work more than for2 or 3 cups .When beans are roasted too fast and too hot ,the coffee oil can turn to coffee tar .
My Xelsis unit cannot handle very oily beans . 2 cups and it STOPS
I only use beans roasted to American Coffee institute recommended procedures .
5helpful
2answers
BUNN VPR commercial coffee pot, not flowing in a steady stream just dripping
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
2helpful
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
8helpful
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
1helpful
Coffee doesn't taste good
even if the machine is new use a decalfier 1 partsolution 1 part water normally when you clean start the machine turn it off for a few minute repeat until emty rinse it very good thatstuff is very corosif try after a good wash and dont forget it like a the pot the older the better hope it work cheers
3helpful
2answers
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
