20 Most Recent Bunn B10 Coffee Maker Questions & Answers
I used Foxhollowrun's solution and went to my local hardware store (Menard's). You can purchase 3/4" Hole Grommets typically found in the electrical department. The brand I purchased was Gardner Bender Model GHG-1575 3/4" Hole Grommets. Here is all that you need to do (very quick and easy):
1) Break away the brittle pieces from the original hole in the resevoir.
2) Remove the old rubber / plastic washers - I found I didn't need them. However, hang onto your metal washer that the drain screw goes through.
3) Slip the 3/4" grommet around the hole.
4) Place the original metal washer on top of the grommet.
5) Screw the drain screw back into the heater which will seal the grommet via pressure. Be sure not to over tighten it - I just snugged mine up.
6) Put everything back together, rinse several pots of water through it, check for leaks, and you should be good to go.
As Foxhollowrun indicated, you may need to tighten the drain screw a bit if you do have a leak. I lucked out - it worked the first time. I believe it cost me about $2 to fix. Also, I did not need any caulk. If you do use caulk, I was told you need to use food-grade caulk.
One last note - as Foxhollowrun indicated, the grommets are quick thick which is why I removed all of the old washers. The original metal washer is just thin enough to allow the drain screw to be reinstalled.
Thanks to Foxhollowrun for a great remedy!
Bunn B10 Coffee... | Answered on Dec 29, 2013
If you haven't used a replacement carafe, then it is probably a clog in the drip orifice, at the bottom of the basket. Note: don't put hot water in your coffee maker as it will perk faster and cause an overflow. Only use cold water. If you have replaced the carafe then it is probably the wrong size.
Bunn B10 Coffee... | Answered on Oct 01, 2012
You can only use bunn coffee filters or your water and coffee grounds will overflow.
Bunn B10 Coffee... | Answered on Jul 26, 2012
it must be overflowing.Its not leake.
check that if you totally turn the machine off for 2 days .The water still leaks.
If yes then replace the water inlet solenoid.
if not then check float sensor that its working properly.
Thanks
Please rate my work
Bunn B10 Coffee... | Answered on Sep 17, 2011
the safety highlimit might have blown
Bunn B10 Coffee... | Answered on Sep 02, 2011
Good day!!!
You need to replaced the spray head...
you can buy it to this site:
this is a spray head kit..
http://www.cw-usa.com/accessories-home-bunn-springsprayheadkit.html
this is spray head only:
http://www.coffeeespressopro.com/bunn-sprayhead-6-hole-sst-6-078.html
I suggest to buy the kit because its compete..
Thanks for using fixya..
Bunn B10 Coffee... | Answered on Jul 28, 2011
It's an easy fix. If you're handy with a soldering iron, you can get a replacement switch (in your choice of colors - think about that!) at any electronics store, perhaps even Radio Shack. It's best to remove the old switch & bring it in to be matched.
If you're not so handy, I'd look around for one of the old, disappearing "mom&pop" electronics shops that you can still find in strip malls. These guys are happy for your business, and have decades of experience. They can do it for you.
If you bring it into a shop, you can save some money by tearing the coffee maker down first (and putting it back together yourself). Otherwise, you're paying them an hourly rate to do what you yourself can do.
Bunn B10 Coffee... | Answered on Mar 04, 2011
Yes, I have a bunn also. Does the same thing. No way to fix problem, they don't have a shut off when pot is removed. What I did was bought a second pot I use to fill. Or you can use a water pitcher, just fill pot, pour into pitcher then fill machine. Only solution to help with problem, I do this and dont have coffee everywhere anymore.
Bunn B10 Coffee... | Answered on Feb 11, 2011
Tank lid gasket may be bad,fill basin could be cracked.Contact Bunn on-line.You can go to there website.You may want to call customer service,sometimes there is a replacement program.
Tank lid gasket bad or fill basin cracked and bad.
Bunn B10 Coffee... | Answered on Jan 31, 2011
If you will call customer service with the model and date code at 800-352-2866 we will be happy to help you with this issue.
Bunn B10 Coffee... | Answered on Jan 18, 2011
There is a seal kit that is successful about 90-95 percent of the time in fixing the leaking issue. If you will call customer service at 800-352-2866 with your name and address, we will be able to send you a kit to resolve your issue.
Please call customer service with the model and date code from the bottom of your unit. The number is 800-352-2866.
I do apologize but these are not available. If you will contact customer service with the model and date code, we will be happy to assist you with any issues you are having with the machine.
Bunn B10 Coffee... | Answered on Jul 07, 2010
Assuming that by "switch" you mean circuit breaker, this is indicative of an electrical short. The circuit breaker is tripping to protect from an overload hazard.
You need to rule out if the outlet itself is bad vs. faulty electronics in the BUNN itself. Here's how you can do that:
1. You may have too many appliances drawing power simultaneously from the same outlet or from other outlets sharing the same circuit. If there are other appliances connected, try removing them temporarily to see if the BUNN still trips the breaker. NOTE: If you are using an extension cord, timer or a surge protector, remove it and connect the BUNN directly to the wall socket. Moreover, do not operate appliances on outlets controlled by a dimmer or a switch.
2. If you are uncertain as to what the cause of the problem is, one option is to relocate the BUNN to another outlet on another circuit in your residence to see if it trips that too. If so, the electrical components in the coffeemaker itself are to blame and you should contact the manufacturer and/or an authorized service center ASAP.
3. If the BUNN was the only thing plugged into the outlet when it tripped, try plugging in something else that draws a similar amount of power/wattage to see if it also trips the circuit while running. If so, your outlet is the culprit and/or the circuit is being shared by too many other outlets in your home (particularly true of old buildings). Call an electrician and/or your property manager to inquire about a solution.
4. Type your BUNN model number and the word "recall" into a search engine. If there is a recall in effect that seems to involve the problem you have encountered, contact BUNN for your service and replacement options. If you determine that the outlet is working correctly and the circuit is not overloaded and you suspect the brewer is at fault but there is no recall notice, consider filing a report with BUNN and/or the Consumer Product Safety Commission. This is a serious safety hazard and needs to be reported to the appropriate parties.
Is the coffee coming out hot enough? If you measure the coffee as it comes into the carafe, it should register at 175-185 degrees. If it doesn't, then it is a problem with the machine and needs to be replaced. If it is that temperature, then the carafe needs to be replaced. Please contact customer service with the model and date code located on the bottom of the machine. If the machine is 3 years or less it can be replaced at no cost. If over 3 years, it can be replaced at a reduced cost.
Bunn B10 Coffee... | Answered on May 19, 2010
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Bunn B10 Coffee... | Answered on Mar 25, 2010
Bunn B10 Coffee Maker Logo
29 questions posted
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Bunn Coffee Makers & Espresso...
  • Bunn Coffee Makers & Espresso...
Most Popular Question
bunn b10 b leaks
  • Coffee Makers & Espresso Machines
