20 Most Recent Keurig B60 Coffee Maker Questions & Answers
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Keurig B60... | Answered Yesterday
More costly than a new unit.
Keurig B60... | Answered on May 10, 2019
Same here. (I have the Mini Plus B31) Called Keurig and these are the steps they walked me through. Not sure which part actually fixed the problem, but it worked.
1. Turn off machine. Using a paperclip clean out the holes in the needles (3 in the top, one in the bottom of the k-cup holder).
2. If water is inside the heating core (assuming it is as nothing happened when you tried to brew), with the machine turned off, press and hold the brew button. After 5 seconds the pump will kick on and discharge the water. Make sure you have a cup in place to catch the water.
3. Dispose of that water.
4. Unplug the machine.
5. Wait 5 seconds.
6. Plug machine back in.
7. Turn on.
8. Run empty cycle without a k-cup and only use the minimum amount of water (6 oz).
9. Dispose of that water after it brews (hopefully).
If still nothing is happening, call Keurig.
10. Brew your coffee, tea, choco, etc.
Note: was told by Keurig rep that whenever you use hot chocolate, to run an empty rinse cycle afterwards before brewing another cup. This will help prevent any choco from going up inside the machine and possibily blocking the water flow.
Hope it works! Mine did after following these instructions. The rep also wanted me to measure the amount of water that came out afterwards. Not sure what the next step would be because my call got dropped, but the machine works. Sipping on a cup now...
Keurig B60... | Answered on Dec 30, 2018
Making a good iced coffee is the same as making a good hot coffee except that you put the coffee in the refrigerator and add ice to the cooled coffee. To make the best iced coffee, don't use lousy coffee. so you can't really make that without an espresso machine.
Keurig B60... | Answered on Dec 19, 2018
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Keurig B60... | Answered on Oct 15, 2018
A European Union decision on July 13, 2000, called for a statutory withdrawal from sale of lindane products by June 20, 2002. For "Atlas Steward," "Doff Ant, "Doff Weevil" and "Doff gamma BHC dust," the notices prohibited advertisement, sale, supply, storage and use by the manufacturers and their agents of existing stocks of the products. However, retailers would still be allowed to advertise and sell these products until the June 20, 2002 date.
The Ban Lindane Group, a UK alliance of groups including Pesticide Action Network UK, Womens Environmental Network, Unison, Soil Association and Friends of the Earth, are calling on government officials to have all household products containing lindane withdrawn immediately, before the June 2002 statutory withdrawal. They also call for an awareness-raising campaign since it is likely that these products will remain in people's homes and sheds for months or years to come.
Keurig B60... | Answered on Jul 31, 2018
make sure you have the cup size set appropriately, you may have it on a larger cup than the one your filling
Keurig B60... | Answered on Jun 27, 2018
The solder joint in the tubing. Personally, I don't see a risk but the environmentalists see a risk in any lead at all. The plumbing in my house has ALL lead soldered joints. Now, plumbers are not allowed to use lead type solder. If the water just passes over the lead, there is absolutely minimal chance of problems. Keeping wine in a lead crystal decantor will also leech lead into the drink but, you don't hear all the hype about that. It's all about making the earth green. Toy wagons are being recalled because of lead in the paint. I don't know of ANY kids who ever ATE their wagon.
Keurig B60... | Answered on Apr 06, 2018
First, I'm not a Keurig technician. Since your machine seems to be calcified then the vibration pump is probably clogged or at least the vibration one way valve is stuck open. I DO NOT recommend De-scaling as it causes more problems if the wrong chemicals are used and gets stuck in the machine. Most warranties are voided unless recommended or performed by the MFR. (most just replace the machine, which hints to how hard it is to De-scale a machine.)
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
* Final, Okay, sounds like you opened (voided warranty) the machine already. I don't recommend any repairs on these table models as it's preferred to exchange them during the warranty period. ******************************************************************
*** But if you must tear this particular unit apart then do so very carefully *** At your own Risk! *** The following is just information:
The pump is usually a round cylinder about 1-2 inches round. There is a white nylon tube at one end and another tube out the back which may or may not have a 90 degree elbow fitting. Your looking at the longer end. Set a dry tower and remove the longer white end. There may be clips or screws that holds it together. Be aware of how the pieces come apart and what order. (there may be videos of this on youtube but I haven't checked. Maybe I will do one later.) Expect a small pen size spring (same as an old ball point pen but shorter) and a very tiny metal or nylon ball or bullet shaped piece. Make sure these are cleaned of calcium and sand. Puff out any bits of crud or use a pipe cleaner. Make sure everything is clean. The plunger can be removed and checked but make sure you put it back the same way. This is very TEDIOUS and a lot of labor. This is why it's better to just replace the whole unit. You have already spent an hour just to get to this point. Clean and re-assemble everything. Put back together and refill tank with water. Power up and test.
* Still not working? Junk it. (Keep the pot and cups) Look for a more heavy duty unit as it seams your a heavy coffee drinker and could use a semi pro machine. "Hey, Look at my cool Espresso Machine! Cappuccino anyone?"
Aloha, ukeboy57
Keurig B60... | Answered on Jan 19, 2018
looking for fuses will not solve the problem
triggering the reset button is an indication of over load current and that is a short
take it to an appliance repair shop for repair or junk it
Keurig B60... | Answered on Dec 07, 2017
Keurig B60 Coffee Maker Logo
1,861 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Clayton McCune
Clayton McCune
Lisa
Lisa
Pierre Laplante
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
service center
  • Coffee Makers & Espresso Machines
