20 Most Recent
Bunn VPR Coffee Maker Questions & Answers
How do I get the
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
BUNN VPR NO HEATED WATER
You should call your vendor for service. Especially if it's on loan from them.
*** The following is for information only. Equipment should be serviced by a qualified tech. ***
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater powers up. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* FYI Coffee grounds are usually in pre-messured packets for office use. A simple guide is one tablespoon per cup. (level or heaping spoon is up to you)
* Since your brewer was bubbling at one point. I'm guessing it had water in the pre-heater at one time. But if it's not in use and left plugged in all that time then the water has probably boiled off. Hopefully someone unplugged the brewer prior to the unit blowing the thermal fuse.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
* check bunn.com for free download of VPR manual
Aloha, ukeboy57
Short pot of coffee
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Thermostat adjustment
There is usually a warmer blanket or heat control that will keep the brewer at a ready temperature.
* If your noticing a lot of boiling that continuously runs for more than 30 mins then the brewer needs to be serviced. The thermostat is probably shorted.
* Reheating is normal for table units, especially in a cold office. If it comes on more than normal (say within 5 mins) then have the brewer checked. The thermal blanket is bad and or the thermostat is set too high. (or out of calibration) Needs to be replaced.
* Call vendor for service to be safe
Aloha, ukboy57
Boils the coffee
Aloha, ukboy57
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
No hot water
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (CWTF's have a toggle switch behind the machine). Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
Aloha, ukeboy57
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Bunn coffee maker leaks
Aloha, ukeboy57
Our BUNN vpr is plugged in 24/7 and stays warm all
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
* FYI Coffee grounds are usually in pre-measured packets for office use. A simple guide is one tablespoon per cup. (level or heaping spoon is up to you)
* Final; Getting back to unplugging when not in use. Yes there is a heater in the machine that keeps the tank warm. You can save power by turning off the warmer plates when not in use. Some units have up to 6 plates. The warmer "Blanket" is designed to keep the tank warm enough to brew and not waste heat or electricity. Yes unplug the unit at night if there is no night crew drinking coffee (or tea) But follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. (*FREE*)
Aloha, ukeboy57
Why doesn't it produce hot water?
the electric comes through your thermostat make sure it is turned on all the way clock wise, and then through the high limit Thermal Cut-Off .it could be either one. further testing is the only to know. also it will take 20 minutes to heat up from a cold start... make sure the tank is full of water before plugin in. it will burn your new heating element out in about 2 to 3 minutes..
Will not brew
Make sure the coffee maker is full of water. Keep filling it till water comes out of spray head.. Should take two full pots plus 3/4 of another one. Wait for water to stop coming out of spray head. Now the unit should be ready to brew after it heats up.
How much coffee to use
U can use from 1.75 oz of coffee grinds up to 2.75 oz. That is the norm. U can also adjust it higher or lower depending on your taste.
