LG DLG5932W Gas Dryer Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dryer will not heat up. Just blows cold air
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Nov 26, 2010
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10845426
Points
101584
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 • Dryers
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
1helpful
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
6helpful
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
2answers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Blows only cold air
Check connection to heating elements. My have bad heating elements
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
1helpful
2answers
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
2answers
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
