Https://www.softwarehow.com/sd-memory-card-error-fix
http://www.lc-tech.com/pc/sandisk-rescuepro-and-rescuepro-deluxe/
Download a free program called card recovery pro. It will get as many pictures as it can.
SOURCE: SanDisk 1GB microSD Memory Card
You can't even format them when they are write-protected. I have the same problem with 2 different SD cards. The lock is in the off position but it still says they're write-protected and can't be formatted either.
SOURCE: "memory card not inserted" or "memory card corrupted"
restart ur computer nd then insert the card
SOURCE: I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
SOURCE: i have a memory stck inserted i formatted it on my psp
that is it . there is no enough space for your demanded progress . that means you should buy more space next time . rate please !
SOURCE: i did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
