20 Most Recent SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Questions & Answers
google translate
please how to download movie from youtube USB
http://download.cnet.com/free-youtube-download/3000-2071_4-10875415.html
if this is not right or what you wanted
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE:youtube downloader you might have to try a few times to get it right
hope this helps
SanDisk Cruzer... | Answered on May 06, 2019
The Cruzer drive comes with its own enabling software (the program name you mentioned). You should be able to view that drive using Windows Explorer (to view the files). Then right-click on the RunSanDiskSecureAccess-Win.exe file and select "Run as Administrator". This should execute the program and allow you to utilize the drive after it installs completely.
SanDisk Cruzer... | Answered on Sep 28, 2017
You cannot move the files because it is to large for your Flash Drive.
SanDisk Cruzer... | Answered on Apr 02, 2017
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
SanDisk Cruzer... | Answered on Aug 27, 2015
okay, problem isn't in ur pendrive problem in ur computer, some kind of viruses attack only removable drives, and user didn't find viruses in computer and also antivirus, you should download microsoft security essential here,--- http://windows.microsoft.com/en-IN/windows/security-essentials-download , and update this software insert ur pendrive and start virus scanning as a whole computer including ur pendrive ur problem will surely solve
SanDisk Cruzer... | Answered on Jun 27, 2014
No idea what you're describing.
SanDisk Cruzer... | Answered on Apr 22, 2014
Have you tried to format the drive? try it if not and do let me know.
SanDisk Cruzer... | Answered on Dec 23, 2013
download realdownload software and install it.after that play video on youtube.com you will see realdownloader tab on right top side of video click on it .it will save to downloads in c drive.transfer it to usb.
SanDisk Cruzer... | Answered on Dec 04, 2013
No - otherwise what would be the point of it!
SanDisk Cruzer... | Answered on Nov 20, 2013
Are the files bigger than 4GB? If so reformat the usb as NTFS.
SanDisk Cruzer... | Answered on Nov 01, 2013
I dnwtd
SanDisk Cruzer... | Answered on Oct 09, 2013
Use bitlocker for our password it works good.
SanDisk Cruzer... | Answered on Oct 06, 2013
Open a command prompt and remove all file bits.Windows Button > type CMD and press enter.
  • CD <drive letter:\> press enter
  • attrib -R -A -H -S <file path\file name>
This will clear the read-only bit, archive, system and hidden bits.
Also right click the file and go to security and make sure you have write permission to the file.
Also verify this flash drive doesn't have a physical write protect switch
SanDisk Cruzer... | Answered on Feb 02, 2013
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
SanDisk Cruzer... | Answered on Dec 26, 2012
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
SanDisk Cruzer... | Answered on Oct 21, 2012
A few important bits of information about using faults and possible fixes on usb drives
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps
SanDisk Cruzer... | Answered on Sep 16, 2012
I have blocked my SanDisk cruzer 16 gb because I used password for maximum time how I can unblock it
SanDisk Cruzer... | Answered on Sep 13, 2012
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
Popular Tags
140 questions posted
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
Cruzer SanDisk
  • Cruzer SanDisk
Most Popular Question
cannot access information memory stick
  • Electronics - Others
