20 Most Recent
Polaroid T730 Digital Camera Questions & Answers
Erased images
I had success with this1. Do not save any new file to memory card.2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download recovery software, recommended one is this
photo recovery software (simply because i was using it and it worked)4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Why does the LCD blink on my Polorod T730, so fast can't even make a selection off the menu
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Driver download polroid
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
What type of USB cord plugs into this camera
believe it or not, I have found many usb cables at resale shops like goodwill stores..but you can take you camera to walmart and they can show you a universal usb cable set with different ends on it..
Dark shadow in LCD screen
Hi there:Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
I737 Polaroid camera
You don't need the Polaroid software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I have a polaroid t730
now my computer does no seem to recognize that the camera is attatched at all,
- Do you mean to say it recognized the camera at one time in the past?
- What happens when you attach the USB cable?
- What operating system are you running on your computer?
- Did you try to re-install the drivers?
I not have software
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
All my photos show on
Sounds like "a portion of them" are in an image format which is not recognized by your operating system.
I believe Polaroid is using some variant of the jpg image format.
If the "portion of them" you are referring to are movies, then you must have the proper software installed.
Did you try re-installing the software that came with the camera?
My screen is cracked and
Hello
Thank you for usinf FIXYA!!!
Firstly i will start by stating that this is one of the more popular problems encountered with digital cameras. The labout including the repair parts will cost you round about $45. You will be able to get this done at your nearest camera repair store.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Lock123
Wanted battery closing cover to
Sorry, but FixYa is an online resource only and does not supply spare parts.
Polaroid are not currently officially represented in India, the nearest Asian distributor is Polaroid in Hong Kong. If you contact them then they may be able to assist you to locate the spare part you require.
Phone: (852) 2524-5031
Fax: (852) 2810-6586
Email: [email protected]
Shiro (HK) Ltd.
Suites 4201-3, One Island East
Quarry Bay, HK,
China
If you prefer to contact a different office you may select one from the
Polaroid website.If my answer has been of assistance then please take a moment to rate my answer as the feedback is helpful to me in maintaining the quality of the service I have provided you free of charge.
