20 Most Recent SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Questions & Answers
I'm not in India but I can use a search engine.
http://www.zyxware.com/shop/computer-hardware/flash-memory-and-card-readers/pen-drive/bootable-fedora-12-4gb-sandisk-usb-memory-stick
Here, 4MB USB drives are very inexpensive and not worth the trouble to try and exchange them. I think they're less that $30 U.S.
SanDisk Cruzer... | Answered on Dec 15, 2017
It may have been damaged if you carry it around with you. The most probable issue id the solder comes away from the usb plug inside the flash drive.
SanDisk Cruzer... | Answered on Nov 19, 2017
Try to get a later copy of Adobe reader or get "Open Office" from GNU and try to read it Microsoft software is prone to do this out of my own experience and made me swear like a proverbial sailor
SanDisk Cruzer... | Answered on Oct 01, 2017
These answers are garbage. You should be using "Roofus," you won't have to do any of that fancy formatting stuff. You can just select the drive and ".iso" file in the program and begin burning. https://rufus.akeo.ie/
SanDisk Cruzer... | Answered on Jun 28, 2017
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
SanDisk Cruzer... | Answered on Sep 22, 2016
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
SanDisk Cruzer... | Answered on Oct 13, 2015
Yes, one good way to recover deleted folders and files from Sandisk Cruzer is to use a Sandisk data recovery software. See this step by step guide
How to recover deleted files from SanDisk Cruzer
You may also try this guide
http://forum.001-software.com/pbb/viewtopic.php?f=4&t=13
hope this helps.
SanDisk Cruzer... | Answered on Aug 28, 2015
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!
http://shortcutvirusremover.blogspot.com
SanDisk Cruzer... | Answered on Jul 21, 2015
Your AV software may have created an block for your drive for some reason. You'll need to go in there and remove that block and then you should make an exceptionso it does not see your pen drive as a threat again.
SanDisk Cruzer... | Answered on Nov 26, 2014
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
SanDisk Cruzer... | Answered on Oct 19, 2014
mon usb ne fonction pas es pc ne pas formater
SanDisk Cruzer... | Answered on Jul 29, 2014
It's damaged. Get a new one.
SanDisk Cruzer... | Answered on Apr 07, 2014
Copy all the files onto your computer.
Then reformat the card, to identify and bypass the "bad" spots of memory. Note that flash-drives have a limited life-time -- after too much usage, you will be able to "read", but not "write" to the device. This is a sign that the device is "dying", and should not be trusted with "valuable" data.
SanDisk Cruzer... | Answered on Mar 16, 2014
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
500 questions posted
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
Cruzer SanDisk
  • Cruzer SanDisk
Most Popular Question
data recover
  • Electronics - Others
