SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: I have a Kenmore stackable washer/dryer (apartment
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
SOURCE: Kenmore washer fills with water but no cycles work.
You should always check your lid switch first to make sure that's not the cause, and usually that is the cause for this problem. I had exactly the same problem as described above and did my research online. I found that the best way is to check the lid switch first and sure it was bad. The switch case was actually cracked open and that's the reason for the malfunction of the switch. All i did was using an electrical tape and wrap up the switch case and it works fine again. I was lucky that the switch was fixed just by some tape, others may have to replace the switch completely.
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
