20 Most Recent
Kenmore 88732 Top Load Stacked Washer / Dryer Questions & Answers
My whirlpool stack unit 27" dryer unit puts burn
there. While we cannot assist with
repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service
line should that be necessary. We hope
this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Dryer does not heat and I checked all connections
You might check the website below by entering your model number to see if Sears has your model in their vast library of service information. If so (it's very likely), you will find a complete line-drawing illustration and accompanying parts list.With these, you can determine if your unit is equipped with a thermal fuse that has probably failed, locate it in your machine and order a replacement if needed.
Sears
parts dept.
I get an E7 message
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Squealing sound during spin cycle
Hi, the squealing could be a result of a loose or slack belt or dry bearings, try replacing the belt to see if this cures the problem.
hope this helps.
