A 17 year old Laptop , 99.9% now in the dumpster.
are you going to spend cash on this? if yes why?
if it was a horse it be in the glue factory.
a dead laptop
step 1: is remove that old shorted huge battery now.,
step 2: then that 17 year old useless as a brick RTC coin cell.
replace it now. or BIOS will be DEAD.
strep 3 , a working power pack 19vdc,65watts up. and does the PC fan work now?, if not, it needs lots more cash !!!!
ask if you can get this far.?
above can be done for $10 (8buck pack and 2 buck coin)
leave that main battery out , until the PC runs like new.
do not buy a battery main, do not. unless cash dont matter.
if this far, and the power button fails, then we must strip the PC down, to find out who is shorting the power buses !
or fan is bad, or just packed fully in lint , as all are that old.
do the HP hard reset yet,
see line 6 here, to the HP page on , hard power reset.
http://pcdied.com/black-screen.html#Laptop
and then the other tests. after that.
here are the goals
1: power seems to work (the switch)
2: the fan works, and actually blow air, not packed up
3: screen shows text of any kind, like, "hit F10 to enter HP setup"
as seen for 17 years but not todaY?
4:BIOS key works. F10 key works as prompted . and BIOS screens all work.
5: more, get this far say so... lots more its not a toaster
the HP long reset is here.
posted here 1000 times or more(fixya)
posted at real HP , 1,000,000 + times
on google 1billion hits?
there are 3 ways to lock up.
one is hibernate, and this resets that.
all 4 reset.
its only 1 of 20 ways for any PC lockup.
(20 = module count)
this is only for power lock up.
it's NOT A PANACEA as some think wrong.
https://support.hp.com/us-en/document/c0...
SOURCE: power up
i think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at [email protected]
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
