20 Most Recent Compaq Presario 700 470024-192 Notebook Questions & Answers
why are your using DELL any thing on any HP>??? so wrong that.
there is no free anything, (even lunch) for sure not any OS,
no OS stated btw, windows what? (guess at VISTA)
my guess is you want this old dog to run!
an 11 year old laptop.
HP does not sell HP media recovery kits for this old pc. (CD kits)
nor does Microsoft. now. (only w7 and 10)
this PC came with Citrix, OS or windows, VISTA 32 or 64.
Vista is now officially dead at MS, and at HP.(see exceptions)
HP does not sell vista disks, but the drivers are supported here.
as are manuals there, still there, lucky you after 11 years.
hint soon to be gone.! (10 year rule)
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-c700-notebook-pc-series/3466274
Compaq Presario... | Answered on Feb 06, 2018
LCD is toasted
rip
or its cable bad,.rare.
Compaq Presario... | Answered on Jan 30, 2018
ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
(VGA) Driver:
http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
Chipset Driver:
http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
Wireless LAN Driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
ALPS Touchpad Pointing Device Driver:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
5 in 1 card reader driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Compaq Presario... | Answered on Jan 18, 2018
(VGA) Driver:
Chipset Driver:
LAN Driver
which driver are you looking for, www.driverdownload.com
Compaq Presario... | Answered on Jan 02, 2018
I bet you do not need or want any proxy server.
I bet you question really is how to get internet connected, right?
first off what OS is this, XP> we can not see you, your PC nor your OS. (whats connected to PC, nor if it has wifi options)
is this IE11 your browsers , cant guess that either,?
why not use an Ethernet, Lan cable CAT5/6 and plug in the PC to the router and it all works like magic,
that be first.
if the PCs lan jack (ethernet ) is dead. (and other PCs work on your router) do they./
then we go to device manager and look
see that? then see if the lan chip has driver.
network marked, red/yellow or unknown is bad.
if missing the get it from HP.
HP has zero support on old PCs, it's too old, its in fact 16 years old. support ended . 2007 (17-10 = x)
came with 10/100 Ethernet, new (spec sheet says)
slow. that is.
but what chip that is , is very hard to find out this old
why waste time and money on PC worth $5 used.?
it came with windows 2000 or XP new. which is it?
if the driver is good, or the unknown chip there, ethernet
the when you connect to the router the connection made automatically
then running relic old IE 6? you see proxy question
tell it no, and that sets automatic , gate way ip address to your router. and just works out of the gate.
install firefox v56 and its more easy.
to run and not get bogged down in proxy settings.
avoid IE versions below 11, as all OLD IE's, are virus magnets and zero support, use Firefox, on all old PCs, not updated to W7 !!!
IE = internet exploder browsers)
show just getting a connection, only. browsing is a whole other matter, and 20 browsers free are common.
http://www.pcdied.com/DevMan/internet.html
Compaq Presario... | Answered on Dec 01, 2017
why not ask them,
or other around you obviously using that.
try to know, that each place you go they have rules.
there are less wide open ad hoc networks now.
do to folks doing ******* things there and the owner can be liable.
first is range, its a weak radio, and if too far it cant work
or is slow.
you will need a password to get in. in most places here.
at 1 air port, its password
and my other air port ,they let you in PW free, but you must sign a page that tell them you dont break the rules
that filters all your cruising, (has huge blocking of vast URL)
that is the way of the future, blocks, rules and sign in PW.
at one air port the password is on all vertical pillar in the air port.
clear as day.
UPS requires and account, all do. l get one, use it.
unless doing tracking blind. sure.
again next time at XRAY (a store, or whatever)
ask them, learn to talk, walk to the counter, and say
can i use your wifi, and how do I
they will say , the SSID, the SSID is the wifi broadcasted name.
you click that and enter a pasword
most places do not run AD HOC now, sorry, but those days are shinking fast, the golden days of no rules. are over.
Compaq Presario... | Answered on Jun 27, 2017
Hello there
Hints:
1) You got a driver or device problem,
2) use the drivers that cam with your f700 particulary these ones, 1) video card 2) sound card (sometimes if driver is bad, it can cause these problems)
3) RAM problems, to isolate the problem, if you have the expertise take ount one ram module at a time and turn on the computer. see if these helps!
Compaq Presario... | Answered on Apr 25, 2017
Have you installed the chipset drivers first?
Compaq Presario... | Answered on Apr 08, 2017
Why are you worried about this? You are getting a warning that the hard drive is about to die. In your place, I would copy any data I wanted to keep to the desktop and then replace the hard drive.
You can then image the original drive to the new one and try the restore again.
The Panther\unattend.xml file is created and Windows uses it during the restore process in order to know what to do, copying it from another computer (if you can find one) would probably totally mess up the installation. The reason it cannot be parsed is probably because it was created on a section of the hard drive that has already failed - remember, your hard drive is dying.
Compaq Presario... | Answered on Mar 05, 2017
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Compaq Presario... | Answered on Jan 03, 2017
Do the following:
Unplug laptop cord and remove battery to reset the laptop.
Restart the laptop wint headphone jack IN.
After Windows has restarted with headphone plugged, while windows is on, unplug headphones and restart Windows again with headphones NOT plugged this time.
Compaq Presario... | Answered on Dec 14, 2016
How are you trying to access your E-mail?
Is it via a "web-mail" interface, such as Google Gmail, or Yahoo! Mail, or Microsoft Hotmail, or a similar interface offered by you ISP (Internet Service Provider), e.g., http://webmail.charter.net ?
Or, are you using Mozilla Thunderbird, or Microsoft Outlook, or Windows Mail, or Microsoft Outlook Express to download the E-mail to your computer?
If any of the latter, then your ISP should be able to provide you with "technical support" on how to configure those E-mail agents.
What have you tried?
What error-messages have you received?
Compaq Presario... | Answered on Oct 22, 2016
i have compaq presario c700 .its sound dirver is missing .give me compaq presario c700 sound dirver setup file in my id subhanmirzably@yahoo.com plz
Compaq Presario... | Answered on Jun 22, 2016
If it`s the BIOS password you forgot unplug the CMOS battery from the motherboard. Leave it disconnected for at least ten minutes before reconnecting.
If it`s the Windows password just download Kon-Boot. Google it.
Compaq Presario... | Answered on May 13, 2016
i do not have a product key for but if you can get a copy of xp unattended black edition u can get office 2007 that does not need a product key to install
Compaq Presario... | Answered on Jan 15, 2016
If your going to use a secondary program to fetch drivers for you, driverguide is a joke it only allows a limited number of retrievals and most are way out dated and also will give incorrect drivers. Find the manufactures site and check for the latest driver. Some have their own software to located what driver you need for the hardware. For instance Dell I have a inspiron laptop needs wifi driver wireless 1704. Nothing on my unit in the papers with it or even in device manager told me this. Dell has a program called bootstrap which scams your system and relays driver and updates.Sometimes a specific unit may have a few configurations depending on it factory ordered or store bought. This can make a little work if a list of possibilities shows. Luckily in my case there was 1 listing. .
If you do want to go the route of using a secondary program I would suggest SlimDrivers They stay on top of all drivers. I had to find a sound driver that come to find out the company no longer provides service of such (soundmax) Driverguide gave ma and update for soundblaster (2007). I installed it and ended up with no sound what-so-ever. Slimdriver looked it up and found the very last time it was put out (2003).
SlimDrivers Free
Yes there is a paid version but there isn't really any difference other than No ads and a little quicker in search. The ads are primarily at the end of an install and for you to buy the program.
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Compaq Presario... | Answered on Jan 04, 2016
Compaq Presario 700 470024-192 Notebook Logo
3,570 questions posted
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
sing up facsebook
  • Computers & Internet
