HP OfficeJet Pro 1175c InkJet Printer Logo
Posted on Oct 06, 2010
HP Officejet 1175c powers down after 30 seconds, say, then will not switch bck on until 60 seconds have elapsed.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
100
Points
Hi, I have a similar problem with power on of my HP Officejet 1175c as it does not turn on, when I press the turn on bottom. But if I wait some minutes it might power up for a few seconds and then turn off again. I have tried then to press the "Menu bottom" for a second, and it then sometimes power up and once it is up and warmed up it might print for hours, if you keep it busy. But if you leave it for a while, it normally turns off again and goes back to the "turn off / turn on" switching mode.
I cannot turn off the printer, but has to let it fall into "sleeping mode" and then takes the power from the source.
Does any body have a better more permanent solution, I would really like to have it. Could you replace the power on switch or unit?
Best regards Dan
1helpful
Need to reset my Office jet 6100 to factory setting. I tried holding to go button it did not work also tried to unplugging from back and plug, waiting 60 sec. Also did not work
This is the only Reset procedure. It is a just a printer, not a computer or a phone ;>)
Please see below for resetting the printer:
  1. Turn the printer on, if it is not already on.
  2. Wait until the printer is idle and silent before you continue.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
More items...
Feb. 16, 2018
Factory reset Officejet 6100 - HP Support Community - 6585824
1helpful
How to disconnect warning light on bottom of fuel filter on coaster diesel 1991..?
The electronic switch on the top of the fuel filter housing is the fuel filter warning switch.
To reset the warning light on the cluster you need to do this:
1. With the ignition switch off, disconnect the fuel filter warning switch connector.
2. Turn the ignition switch from off to ON.
3. After more than 3 seconds but less than 60 seconds have elapsed, reconnect the connector.
4. After approximately 3 seconds have elapsed with the fuel filter warning switch closed, the
system confirms the deletion of the illumination information by turning off* the warning light.
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
2helpful
Printer Error Message HP AIO 6210 printer
Hi
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
Riz
1helpful
2answers
The machine is frozen, can it be fixed or time to replace?
Hi
We need to reset the printer, please follow the below steps to resolve the issue.
POWER DRAIN:-
Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-
Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
SEMI_FULL RESET:-
Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-
(Notes - resets will take a while)
Thanks
Riz
5helpful
3answers
1helpful
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know after resetting.
Thank U!!
Chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
Thank You
Hp officejet pro 1175c printer with windows xp ?
This model is discontinued and, according to HP, unsupported now. They do not have, nor will they have drivers/support for it. You can not even BUY a driver CD for them to send, as they don't offer one.
BUT.. if you go onto HP's Live Chat and tell them you need drivers, etc., they'll tell you the same.. but they should also offer you a 'great bargain' -- which would be to upgrade to a supported model (newer) that is a refurbished unit at a 'minimal cost' (which I don't know what the amount is- sorry).
Just make sure you have your SERIAL NUMBER from the unit available.
Then you can decide if it's worth it.. or ...
second option would be to go out to a store and purchase a newer model.
Sorry... that's as good as it gets...there are no drivers posted anywhere for XP and this unit!
Maggie B
k24674
Grand Canyon Tech
Grand Canyon Tech
