Well, I am providing you four tips which you can consider to recover Windows administrator password if your forgot or lost it:
TIP 1 - Use password reset disk
Windows-based system was designed to be able to create windows password reset disk without any other third party tools. So you can make use of a password reset disk to reset your Windows password in case you lose or forget your Windows password.
TIP 2 - Restore the operating system
Windows password recovery can be performed by restoring the operating system. Since restoration leads to data deletion, the solution can only work if you have a clean and updated backup of your hard drive data stored somewhere else.
TIP 3 - Use Windows Boot disk
The boot CD for Windows can be used to reset the administrator password. This disk enables you to repair Windows OS, thereby, setting your administrator password as blank.
TIP 4 - Use password recovery software
This is considered as the best windows password recovery solution, however, is to download a third party software. These tools enable you to reset Windows administrator password without posing any threat to your hard drive data. Among so many password recovery software, windows Password Recovery 6.0 is an easy-to-employ application which can be used to reset lost or forgotten password of any Windows system. Now execute the following steps to recover your lost windows password if you haven't prepared anything.
Step1: Login to a computer that can link to Internet. Download Windows Password Recovery from
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and install it on that PC.
Note that: there is an .ISO file. Burn the .ISO file to a CD/DVD or a USB flash drive
Step2: Get out the newly created CD/USB and insert it to the locked computer.
Step3: re-booted the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old passwords were removed.
Step4: logon PC without password and setting the new password
It
is asking for your administrator password or bios pass word,it is
difficult to know or provide any help for the password issue ,you can
take help of your recovery CD.
Check the bios version if the laptop has BIOS version 1.20 then roll back to BIOS version 1.19 if it works that's great.
BEFORE DOING RECOVERY YOU CAN TRY
WITH BACK DOOR BIOS PASS WORD,CHECK THE MANUFACTURER OF THE BIOS IF IT
IS PHOENIX/AWARD/ BIOSTAR(The backdoor password is a BIOS password that
works, no matter what the user sets the BIOS password to. These
passwords are typically used for testing and maintenance. Manufacturers
typically change the backdoor BIOS passwords from time to time.)
It seems Acer aspire 9300 has TOSHIBA bios in that case user name/password:--- Toshiba/Toshiba.Even you can hold down the left shift key on the laptop while it is booting up.
SOURCE: acer aspire 9300 backdoor or bios password
Clear Password
PIN Pad: Bypassing Password Check, Keep shorting G3 (2 triangle pad) as above PIN pad and
then powering on the system will force the BIOS to clear Supervisor and User passwords. That
means both the power-on and setup passwords are all cleared.
SOURCE: can not remember password so i can reset laptop to factory settin
the only way u can reset ur password is to remove ur mother board and cross wire the bios chip with power on i can send the directions if ud like please email me at
[email protected]
my name is mark
