20 Most Recent Acer Aspire 9300 Notebook Questions & Answers
The way you describe the problem , it sounds like your graphics card went bye bye .
Acer Aspire 9300... | Answered on Jan 15, 2018
Been there. You need the driver in the Acer Site. Note !! you need the Acer Orbicam WHQL Driver as well as the Acer Orbicam Utility. The Orbicam webcam is a USB device. Pls follow this steps in sequence.
1. Install ChipSet/Lan Support.
2. Install Acer Orbicam WHQL Driver
3. Install Acer Orbicam Utility.
Acer Aspire 9300... | Answered on Jan 27, 2015
ftp://ftp.work.acer-euro.com/notebook/aspire_9300/manual/AS%209300_7000%20User%20Manual.pdf
Acer Aspire 9300... | Answered on Apr 14, 2014
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
Acer Aspire 9300... | Answered on Apr 13, 2014
backlight, inverter or loose screen connector into system board
Acer Aspire 9300... | Answered on Feb 14, 2014
thats is because of heating issue and there might be some programs that are using cpu while idle,check what are the programs running in the background and disable what are not neccessary,also clean cpu fan and all other heatsinks and re-apply thermal paste,that will solve your problem
Acer Aspire 9300... | Answered on Sep 26, 2013
You have a typical problem of the laptop overheating or the video chip is going out. There is no adjustment...
Acer Aspire 9300... | Answered on Feb 14, 2013
Is it really old? Take it to your local computer shop and see what they can do about it.
Acer Aspire 9300... | Answered on Jan 24, 2013
The advice above is literally the worst I've ever read on the internet.
Acer Aspire 9300... | Answered on Jan 13, 2013
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Acer Aspire 9300... | Answered on Dec 08, 2012
Hi guys,
this question is quite old, but perhaps the cause of the problem is still interesting. Have a closer look to your board. You should find a chip with the caption "ene" in the upper left corner. Left beside that chip is a crystal called X1. In my case this crystal was defective. So no reflow of the gpu or esd will help. :-(
Acer Aspire 9300... | Answered on Jun 07, 2012
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Acer Aspire 9300... | Answered on Jun 05, 2012
The Acer Aspire 9303, is part of the Acer Aspire 9300 series of Notebook PC's.
I have good news, and not so good news.
Good news:
This is a link to free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the 'paragraph' that starts with Aspire 1200. (1200 in Blue)
Go down to the 13th line (8390Q), scroll across, left-click on 9300.
[ Ignore the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (9300), it may take up to 30 seconds to download.
After the file has downloaded, bring your mouse to the bottom of the page.
The 'ghosted out' Navigation bar will appear.
Go all the way to the right, and click on the Adobe PDF icon.
(Looks like a three pointed 'star' ]
Start on Page 69. (PDF file page number at top)
Direct information for removing the Fan Assembly, is on Page 78.
Not so good news:
The Display Assembly has to be removed, and the laptop disassembled down to the motherboard removed, to access removing the Fan Assembly.
1) Remove ALL Power. Remove the AC adapter (Charger), and Battery.
2) Advise use an ESD wrist strap, and connect it's alligator clip to a good ground source.
Average cost is around $3 to $6. Cheap insurance, so you do not Static shock, the delicate hardware components inside your computer.
Do not wear one, and have it connected to a good ground source, and you can use the laptop for a doorstop.
3) Use a multi-compartment container, for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise Do Not mix them up.
4) If this is your first time, make a record as you disassemble. Make notes, and drawings, and/or use a digital, or video camera. Use good lighting, and make legible notes.
Nice to have a Service Manual, but even nicer to have your own personal record to refer back to, in case you are interrupted.
For additional questions please post in a Comment.
Regards,
joecoolvette
Acer Aspire 9300... | Answered on May 25, 2012
Well for one it sounds like you may have used a monitor other than the laptops and selected this as the default monitor. When you boot the system go into your monitor settings and select the on-board graphics which came installed with your unit. also it could be that the screen has gone out. But if you have been playing with an external monitor this may be your problem. Open Control panel find your graphics and restore this back to default monitor settings.This can be set in BIOS settings as well back to on board graphics and display. Remember to rate and give testimonial this is how i earn my achievements here of FixYa Thanks in advance
Acer Aspire 9300... | Answered on Apr 28, 2012
Acer Aspire 9300 Notebook Logo
314 questions posted
Ekse
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
pics load use chat facebook
  • Computers & Internet
