Thanks very much for your assistance
When ever it get to the Rinse and Spin Stage,it stop and it does not do anything.
Please advise us what to do on this:Aquarius Hotpoint WD440. 1400 Spin
We look forward to getting your assistance
Thanks in advance!
Hotpoint Wd440. I had the same problem, lights flashing and water not draining, First drain your water (syphoning works but tastes ****), if the machine drains then you know its not blocked. Then put the machine on M for about 5 mins, then put it on fast spin. This should do the trick, it worked for me anyway. Good luck.
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
getting error code f-01. Machine fills with water then pumps back out again. Does anyone know what this code means?
Mark
