Jabra Stone Bluetooth Headset Logo
Arshad Wali Mohammad Awm Posted on Aug 28, 2010
I have brand new jabra stone And when I put it on charge, everytimr I have unplug the charger from ac outlet and then the red charging light starts charging but after few seconds it automatically goes off
David
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Feb 01, 2016
David
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
Helped
637
Points
Same with mine. I keep it on charge, the red light on the charging dock lights on for 30 seconds and goes off. Tried keeping it on charge for more than 2-3 hours. Still no use, I cannot switch on my Earhook. There is no indicator on the battery icon or the Bluetooth icon. Do not know what to do, I bought is only three months back in USA and now I am in Africa. DO not know what to do.
Anonymous
Level 1:
  • Posted on Nov 13, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
637
Points
My head set does the same I haven't found out how to fix it or turned on it has being charging for more than two hours
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1090
Points
14
Just leave it its charging even when light out
  • Anonymous Nov 13, 2011
    For how long ? No green light ever appears
2answers
Jabra extreme2 will not charge
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
Hello my jabra wont light up when it is fullcharge? can you help me?
The headset light turns off when it is at full charge. If it is not charged yet it will be illuminated red.
Found this in the online manual:
http://img5.jabra.com/sites/Jabra/GNimages/Products/Stone_Manual_EN_NA_8404.pdf
1helpful
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
5helpful
2answers
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
3helpful
3answers
New jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
6helpful
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
