20 Most Recent Jabra Extreme2 Bluetooth Headset Questions & Answers
If your Jabra Extreme2 Voice guidance is not turned on - i.e. you only hear beeps when you power on or a call comes in...
Cause: powered on or off with answer button depressed
Solution:
1) Power off
2) Hold down answer button (the one that lights up Jabra)
3) Power on
4) Release answer button
You may need to repeat.
Jabra Extreme2... | Answered on Mar 23, 2019
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Jabra Extreme2... | Answered on May 30, 2016
The battery in those is small and it is easily exhausted and overcharged and then it is not about to be charged.
Your battery is no good. If you've had it for a while then the battery's life has been used up. All rechargable batteries have a certain amount of times they can be discharged and recharged. Once that amount is met end of battery. If it is new then send it back for a replacement.
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
Jabra Extreme2... | Answered on Sep 04, 2013
Mute/Unmute: Tap both the Volume up or
Volume down button at the
same time
Jabra Radio... | Answered on Apr 03, 2019
you can buy new ones for very cheap don't be so darn cheap
Jabra Radio... | Answered on Mar 20, 2019
PARID ????????
Jabra Radio... | Answered on Feb 26, 2019
https://www.bestbuy.com/site/questions/jabra-steel-bluetooth-headset-black/4860101/question/ae4052f2-4f6e-3f45-b0c2-ed44931c70b5
While connected to your cell phone, with bluetooth, use the cell phone volume settings to increase the volume.
Jabra Radio... | Answered on Feb 19, 2019
Jabra Extreme2 Bluetooth Headset Logo
23 questions posted
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
jabra extreme stays red when am charging
  • Radio Communications
