20 Most Recent Makita 12 Volt Cordless Drill/Driver Kit Questions & Answers
Here is the parts breakdown. It may help you with the disassemble. https://www.ereplacementparts.com/makita-6011d-cordless-drill-parts-c-97_106_107_561.html
Makita 12 Volt... | Answered on Oct 31, 2017
It sounds like the problem is the battery. It sounds like there are shorted cells in it so that it starts to draw too much current from the charger and the charger shuts down as a safety measure.
I hope this helps,
Happy New Year,
Mark
Makita 12 Volt... | Answered on May 01, 2016
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Makita 12 Volt... | Answered on Dec 05, 2014
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Makita 12 Volt... | Answered on Aug 23, 2014
a bit of heat usually works.
Makita 12 Volt... | Answered on Nov 17, 2013
Here is website that you can download the diagram for charger. It's free.
Hope this helps.
ereplacementparts.com/makita-dc18sc-charger-parts-c-97_376_3678.html
Makita 12 Volt... | Answered on Oct 21, 2013
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Makita 12 Volt... | Answered on Jul 08, 2013
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Makita 12 Volt... | Answered on Apr 20, 2013
Stick the speed fix to 1, put drill in reverse, and hold on to the chuck as hard as you can, and squeeze the trigger.
Makita 12 Volt... | Answered on Jun 07, 2012
Hi Soren,
I hope this link gets you what you are hunting for.
http://www.ereplacementparts.com/makita-dc18sc-charger-parts-c-97_376_3678.html
thanks
Fame !
Makita 12 Volt... | Answered on Oct 28, 2011
you might have to hit it a couple times to loosen the chuck
Makita 12 Volt... | Answered on Jul 04, 2011
Makita 12 Volt Cordless Drill/Driver Kit Logo
Popular Tags
88 questions posted
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
View Most Popular
Makita Drills
  • Makita Drills
Most Popular Question
batteries dont charge
  • Drills
