20 Most Recent Jabra BT350 Bluetooth Headset Headset Questions & Answers
TIME TO REPLACE IT
Jabra BT350... | Answered on May 20, 2018
I had the same problem... the battery is part # 501235 and is 3.7v 150 mah (yes, it's tiny). Searching for this on the web yields such a part at various places but not any retail options that I could find.
I took it apart per the instructions at instructables.com (above) and then jump-started the battery using a maglight penlight. Sometimes rechargeable batteries get "stuck" on empty when they drain down to absolute zero and have trouble accepting any charge... To jumpstart it, do this:
Get a Maglight AAA or AA penlight (2 cell) and unscrew the end as if you were going to replace the light bulb. The bare bulb must be on when the reflector is removed (or, perhaps the batteries are dead).
Remove the bulb.
Obtain two short (1") pieces of bare 22-26AWG wire and insert them into the holes where the bulb wires were previously inserted.
Using a multimeter, determine which wire is positive and which is negative
Align the + terminal of the rechargeable battery in the Jabra with the positive wire identified on the flashlight - do the same with the negative terminal. Hold the flashlight on the battery for a minute or so to allow some of the current from the light to slightly charge the jabra battery.
Before putting the Jabra back together, try the AC or USB power cord - you should now get a solid red light if it is charging.
If not, try to "jump" it again for another minute or two or three.
If this doesn't work, the battery is probably totally shot - maybe you'll have better luck finding a replacement than I did.
The Maglight isn't necessary, but it is a simple way to obtain the 3.0v DC power source. You could use a similar power source to obtain the same effect (probably 2.7-3.7v DC is best).
Jabra BT350... | Answered on Jan 29, 2015
To turn the Jabra BT350 on you have to Press the answer/end button to turn on your headset!
Jabra BT350... | Answered on Jan 04, 2015
http://www.youtube.com/watch?v=C5koqNKSjB8
I could try and explain it but this video link below explains it reaaly well
http://www.youtube.com/watch?v=qUtvbRSx00A
laptop has to have bluetooth ability if it doesn't get an usb bluetooth adapter
Jabra BT350... | Answered on Nov 02, 2014
It likely that rechargable battery is not taking a charge any further or the contacts point of plug are damaged. Sorry to say "it's dead, Jim."
Jabra BT350... | Answered on Aug 05, 2013
Jabra BT350 Bluetooth Headset Headset Logo
236 questions posted
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
replace battery
  • Radio Communications
