20 Most Recent
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Questions & Answers
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
How do I pair my
Connecting a Bluetooth headset or car kit
You can listen to
music over a Bluetooth stereo headset, or have hands-free conversations
using a compatible Bluetooth headset or car kit.
It's the same procedure to set up stereo audio and hands-free.
- For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
- Before
you connect your headset, you need to make it discoverable so your
phone can find it. You can find out how to do this by referring to your
headset manual.
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Tap Bluetooth settings.
If the Bluetooth check box is not selected, select it to turn Bluetooth on.
Make sure that the headset is discoverable.
Tap Scan for devices.
Your phone will start to scan for Bluetooth devices within range.
When you see the name of your headset displayed in the Bluetooth devices section, tap the name.
Your phone then automatically tries to pair with the headset.
If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices
section. When the Bluetooth headset or car kit is connected to your
phone, the Bluetooth connected icon is displayed in the status bar.
Depending on the type of headset or car
kit you have connected, you can then start using the headset or car kit
to listen to music and/or make and receive phone calls.
How to charge Motorola N356
If it is not charging you first need to make sure your charger is good. If it is not replace it, if it is then your headset batter is probably bad and you will need to replace the headset.
I paired my jabra bt
Go to Jabra site to confirm compatibility:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabrabt2015.aspx?submit=y
It says that they are compatible.
I have a Jabra GNM-OTE3
I can confirm that the headset works. Suggesting two steps:
1) Confirm that you are holding both the power button AND the answer button for at least 5 seconds. When you release both buttons, the light will go on steady. Does the light go on steady? (If not, you may have a headset problem.)
2) Turn on bluetooth on your phone. Then "search" for the (now with light on) headset. (If the light is off, repeat step 1). The moto should discover the headset, and connect. It may prompt you for a pin...and the default pin code is 0000.
Hope that helps. dw
I have a Jabra VBT3050.
Hello and Welcome to fixYa!
The default passcode for the quoted model is 0000. try entering that passcode code, when pairing the device with the mobile.The pass code can't be reset at device end...
Best of Luck,
Concerned...
How to install on laptop 3200
Dont know what laptop your talking about but you have to see if your laptop even has bluetooth. if it doesnt have one your going to have to buy a bluetooth adapter.
Can not get it paired to iphone 4
Goto Preferences (the gray gear icon - should be on your home screenThen BluetoothTurn your headset on (on my phone this is done by flipping down the plastic tab that touches your upper cheekThe iphone screen should then see it and ask for a pairingIf it doesn't, one by one press any other adjacent icons until you see the request to enter the Pairing passcodeIf you don't know the pairing passcode, most headsets use 0000, but if that doesn't work you will have to enter into a Google search"(Your headset brand and model) Bluetooth Passcode"and search the resulting links until you find it
Cant connect my Jabra BCE
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Problem pairing my Jabra vbt 2050 with my blackberry storm
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
