Computers & Internet Logo
Posted on Mar 28, 2017
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by virus, the soon i tried connected to computer my card got courepted and all the photos were not to be seen. i tried to recover from the recover pro software, but it only shows only thumbnails, and it dosent open the images and even i cannot copy and save the image files, can anyone help to recover the images cause those images are very important. i have formated once my cf card after the error. and now iam not using the card in case i dont want to re-rite on the existing images. can any one help?
renu sood
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on May 23, 2017
renu sood
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
6
Questions
0
Helped
6544
Points
32
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
5 Related Answers
Inky
Inky Fingers
  • 705 Answers
  • Posted on Sep 17, 2007
SOURCE: Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Anonymous
  • Posted on Oct 28, 2007
SOURCE: Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Anonymous
  • 790 Answers
  • Posted on Nov 02, 2007
SOURCE: DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Anonymous
  • 111 Answers
  • Posted on May 16, 2008
SOURCE: problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Anonymous
  • 480 Answers
  • Posted on Jul 25, 2008
Hey jenmar63,
There are multiple photo recovery programs out there that usually do a fairly good job of recovering images off of memory cards. I would search the internet for photo recovery programs and you should get multiple results with some being free and some at a charge. I would try the free ones first since just because one program doesn't work doesn't mean another program won't. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
My nikon d70 will not regonize the sd card and gives a format signal
The D70 uses CF (compact flash) cards - I hope you are simply misnaming the CF card. But, if you did use an SD card, it would explain how you could have bent a pin.
I understand that Nikon is moving away from CF cards because of the 'bent pin issue' as well as the limited capacity of the CF card.
So, first I would try a CF card (any size) in the reader. If it still doesn't work, then I think you might check with a camera repair shop. If it is a bent pin, they can fix or replace the card reader. Note that the D70 body can be replaced with an EX rated used body for under $90 at https://www.keh.com/shop/nikon-d70-6-1-megapixel-digital-slr-camera-body-only-9782.html
Thus, I wouldn't pay $100 to have the reader fixed unless there are extenuating circumstances. Good luck.
2answers
Hi!
1helpful
Do the Nikon D100 and the D70 share the same in camera Compact Flash unit - not cards - but the hardware to accept and read the CF card? I have a bent pin in the D70 and want to know if I can change out...
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
1helpful
I have a Nikon D70. Camera doesn't read CF.
Sometimes pins inside take strain.  Read up on how to replace the CF pin unit.  Not too difficult as long as you don't force anything and remember to retrieve the little metal strip....
2answers
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 • Cameras
Nikon d70 does not want to format
This camera allows at most a 4GB CF card, are you trying to use something larger, or does it do this with any size card? Also make sure card isnt write protected. Failing either of these suggestions, its possible that something has happened to the card slot internal to camera, they can be quite fragile.
Dynamite,
SteveK
D70 digital camera
could be bent pin in the memory card slot
2answers
CF Excessive Power
Nikons and Fujis keep the CF slot powered, and "poll" it every now and then to see if a card has been removed or inserted. So yes, a camera may drain batteries much faster with a CF card than it does with an XD. But if it really does do this, then someone at Fuji deserves to be on the street, looking for a new job. Polling a card every few seconds does not have to be a traumatic experience to the camera. A Nikon can sleep for months, and not show appreciable battery drain. After what I've seen in the horribly slow CF write times of the S3, and the large artificial difference in write times between CF and xD on that camera, I'd say someone (or several "someones") at Fuji is doing everything in their power to make CF look bad and steer people into xD.
Grand Canyon Tech
Grand Canyon Tech
