20 Most Recent Nikon D100 Digital Camera Questions & Answers
Hm, the photo doesn't work properly, could you re-upload it? And did you check the manual for your specific device? If not, you can find it here: Nikon D100 PDF Manual Download
Nikon D100... | Answered on Jun 25, 2018
Sometimes lens mount to camera can get loose but mostly lens has a electrical connection problem that you would be better off just replacing lens with a good used one from eBay.
Nikon D100... | Answered on Jul 08, 2017
Format the card in the camera.
Nikon D100... | Answered on Nov 27, 2016
Are the controls set in a position that does not allow flash? For example, in some scene modes, flash is excluded, as it is in S or A modes. Also, if your camera has a flash control, make sure it is not in "Flash off", a lightening bolt with a diagonal line through it.
Nikon D100... | Answered on May 17, 2016
Nikon no longer has the D100 manual on line; but if it is like the more modern Nikons, you will be able to select the resolution in mp from one of your camera's built in menus.
Nikon D100... | Answered on Nov 05, 2015
sounds like an incompatability issue to me I would check with nikon web support
Nikon D100... | Answered on Mar 15, 2015
This is an odd problem if you're using a standard lens. I've been told that it's called photo chromatic aberration and it's a fairly common problem with inexpensive big (600-1200mm) telephoto lenses.
If it's happening with a good quality standard lens this suggests that there may be a problem with the autofocus not being quite set when you take the first shot then being fully adjusted by the time you take the second shot.
I'd suggest contacting Nikon support at www.nikon.com to see what they suggest. Be sure to provide them with information about what kind of lens you are using and what the light conditions are.
Nikon D100... | Answered on Dec 04, 2014
The D-90 and D-100 are similar so this may work for you. On my D-90, you go to the menu, then click on the little pencil Icon. The top line will read: Reset Custom settings." Click on this line then click "yes" to reset all custom settings back to default. You can also reset individual settings back to default by clicking on the line for the specific setting you want to reset.
In addition, on the top right side of the camera you will find a "+/-" button and an "AF" button. Both are marked by little green dots. Press these two buttons simultaneously for several seconds and it will reset most of the custom settings back to default.
Nikon D100... | Answered on Jun 27, 2014
Unprotect the files by pressing the key button while in playback mode. See page 119 of the manual at http://www.nikonusa.com/pdf/manuals/dslr/D100_en.pdf
Nikon D100... | Answered on Nov 05, 2013
Unprotect the files first by pressing the key button while in playback mode. See page 119 of the manual: http://www.nikonusa.com/pdf/manuals/dslr/D100_en.pdf
Nikon D100... | Answered on Aug 26, 2013
Unprotect the file(s) by pressing the key button in playback mode. See page 119 of this manual: http://www.nikonusa.com/pdf/manuals/dslr/D100_en.pdf
Is a CF card in the camera?
Nikon D100... | Answered on Feb 15, 2013
If the view finder is dim it is likely the iris of the lens is stuck and cannot acquire correct lighting. It need to be repaired by disassembling the lens.
Nikon D100... | Answered on Feb 13, 2013
Nikon D100 Digital Camera Logo
178 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
delete protected files
  • Cameras
