20 Most Recent Nikon D70 Digital Camera with 18-50mm Lens Questions & Answers
I can duplicate your issue on my Nikon D810. You may have set it to display the areas that are over exposed or "clipped". Go to "Playback Menu", select "Playback display options", uncheck "Highlights".
Nikon D70... | Answered on Jul 31, 2018
I find connecting to the camera with a computer to be occasionally problematic. I STRONGLY suggest taking the SD card out and reading it directly with the computer.
Nikon D70... | Answered on Dec 22, 2017
You can download a manual by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Nikon D70... | Answered on Apr 07, 2016
Probably need to send it in.
Do you have a flash attached? If so, remove it.
Also, you might try resetting the entire camera,, in the menu settings.
Finally, remove the battery for a minute, recharge and replace.
See if any of that helps...
Good Luck!
Nikon D70... | Answered on Jul 14, 2014
If it is an SD or SDHC memory card the answer is yes.
Nikon D70... | Answered on Jun 03, 2014
Sccording to my D70 manual:
"CHA"= this card cannot be used. try Nikon approved card,, Try reformatting card in camera, not PC, clean card contacts in camera using camel hair brush and blower.
You might also use a small pen and press the hardware rest buttin in bottom of camera (page 200 in manual)
Nikon D70... | Answered on Oct 09, 2012
The camera is having trouble accessing the memory card. Try cleaning the contacts, both on the card and in the camera, and/or try a different card.
Nikon D70... | Answered on Jul 19, 2012
This is a common issue with the d70 model the cf card unit needs to be changed.
Nikon D70... | Answered on Jul 18, 2012
If there are brackets around the CHR, it means the card is locked. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If there are no brackets around the CHR, it means the camera cannot read your memory card. Try a different card.
Nikon D70... | Answered on Jul 13, 2011
Follow the directions in the camera manual on page 200 for a hatfware reset. There is a button on the bottom of the camera. It is held down for a few seconds to reset the hardware. If that does not work, ir sounds as if the meter may have gone bad and further investigation by a qualified service tech would most likely be in order.
Nikon D70... | Answered on Apr 07, 2011
If you want to delete all the pics at once, the easiest way is to format the card in the camera.
Nikon D70... | Answered on Nov 26, 2010
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. Control the aperture from the camera, just as with other lenses.
Nikon D70... | Answered on Nov 15, 2010
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory card to the computer via either the camera or preferably with a usb card reader , run the program.
On the program , select the dig deep option for accidentaly deleted files or dig deeper for a formatted card. Then select the card you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the pictures were lost. Save the files to a location on the computer hard drive and not back to the memory card as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Nikon D70... | Answered on Sep 29, 2010
Try switching to the EN-EL3 EN-EL3a 1500mAh Li-Ion Battery for Nikon D70..or a 1800mAh.
Nikon D70... | Answered on Mar 26, 2010
Press the Zoom-in button.
Nikon D70... | Answered on Dec 30, 2009
Press the zoom-in button one or more times.
problem in card holder repair or replace
Nikon D70... | Answered on Oct 05, 2009
Get a usb memory card reader. I have never ever used the cord from camera to pc. It's so much easier to just take out the card.
Nikon D70... | Answered on Jan 02, 2009
I have no solution, but I wanted to add that I am having this same problem. You are, unfortunately, not alone. Jean
Nikon D70 Digital Camera with 18-50mm Lens Logo
Popular Tags
50 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
nikon d70s pictures turn out black over
  • Cameras
